Results 1 to 10 of 10
  1. Trying to find a way to change color of shown subtitles when viewing dvds on computer. Like a video player that can do this in its options/settings?
    I.E watching dvd with subtitles. Its ugly yellow color. Want to change to white WITHOUT having to rip the dvd and extract the subs and change there. Im looking for a way to change the color durring stream of video. Like a filter option for the playback.
    DVD subtitles are stored as images and it makes it a bit tricky to adjust the font settings. Just changing color wouldn't be that hard though...but I haven't seen any such feature in any player.
  3. Originally Posted by Baldrick View Post
    Yea, that's pretty much what I found out when I did some online research. They say it wouldn't be too hard to just adjust the color but haven't found any player or something of the like that supports that feature.
  4. Following up with this thread. I found something weird going on with DVD's and win7. While I was continuing to look into changing subtitle colors during playback. I copied my dvd's contents to my Hard drive and loaded the main VIDEO_TS.IFO using MPC. Magically the subtitles are now white. So I tried loading the VIDEO_TS.IFO from the physical DVD into MPC and the subtitles are yellow. I then load the VIDEO_TS.IFO into VLC and THEY ARE WHITE. Then I try the DVD's file VIDEO_TS.IFO in VLC and they are YELLOW. So this change has something to do with Windows and how it reads dvds? Because its not the video player and the only difference is the location that I'm reading the dvd from.
    Any guesses?
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    The Popcorn series of media players have that facility. The C200 has the option of changing colours and size and position of subs etc. But you would need to rip your DVD's/Blu ray discs to ISO on a hard disc or install a DVD unit in the C200. I didn't do that with mine so I don't know if the unit will do it from a physical DVD in it.
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
  6. Mentally Deficient Mr.Delusional's Avatar
    Aug 2012
    The ghetto of Emerald City
    You can change the colors in Vlc. I haven't tested it in Mpc or Mpc-Hc. In Vlc just right click on the screen. Scroll down to tools>>>click preferences, then on the left side, scroll down to Subtitles & OSD. And now choose what color you want. Be sure to close and restart Vlc for it to take affect.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    But can you change DVD subtitle colors?
  8. Mentally Deficient Mr.Delusional's Avatar
    Aug 2012
    Actually I'm totally wrong. It's the color of the closed captions that can be changed, not the subtitles. I do apologize.
  9. DECEASED
    Jun 2009
    Heaven
    Give a try to Mplayer, which is known for ignoring the original colors and reducing everything to white text -.-
    To my eyes at least (and to the eyes of many other people as well), yellow subpics are more readable than white subpics.
  10. That's all very interesting but does anyone have any ideas as to the weird behavior I've witnessed when reading the dvd from the dvd drive or from the physical hard drive; why its changing subtitle color to white when views from Hard disk but not when viewed from dvd drive?
