Results 1 to 30 of 30
    May 2014
    Planet Earth
    Hi folks,
    Following on from my previous thread (here), I am hoping to re-encode 800 video clips which are 3 hours and 4 minutes combined and 11.7 GB in size from my friends camera and fit them onto 2 DVD's (no authoring or menu's required, just pure video footage).
    GSpot gives the following info on the codec of the clips:
     Container
    DVD "VOB" format
    MPEG-2 Program Stream << { 1 vid, 1 aud }
    Sys Bitrate: 10080 kb/s VBR
    Video
    Codec: MPEG2
    FPS: 25
    WxD: 720 x 576
    Average birate: 8804
    Audio
    Codec: AC3
    Info: 0xbd[0x80]:48000Hz 256 kb/s tot , stereo (2/0)
    I have a .txt. file with paths to all the clips and I am using this command in ffmpeg:
    ffmpeg -f concat -i d:\video\mylist.txt -c copy d:\video\output.mpg
    The result is 10s of errors every second (see below) and the output video freezing on the first frame and not playing any longer than 7 seconds:
    [mpeg @ 00000000055fe720] buffer underflow st=1 bufi=37828 size=66833
    [mpeg @ 00000000055fe720] buffer underflow st=1 bufi=39865 size=66833
    [mpeg @ 00000000055fe720] packet too large, ignoring buffer limits to mux it
    [mpeg @ 00000000055fe720] buffer underflow st=1 bufi=41902 size=66833
    I have no previous experience in video encoding and would appreciate assistance.
    Aug 2013
    Central Germany
    DVD Authoring should be done in software specifically made for this purpose; ffmpeg is not.
    A "DVD Video" is more than just one movie, most of all it is a logical structure. More than just a concatenated clip sequence. I would not even be certain if ffmpeg knows that all these clips should be treated as DVD Video compatible while remultiplexing.
    By the way, many good DVD authoring tools prefer elementary video and audio streams.
  3. Try this ...
    ffmpeg -f concat -i d:\video\mylist.txt -c:v copy -c:a copy -f vob d:\video\output.mpg
    You now only copy the video stream and FFmpeg re-encodes the audio stream to its default settings. Also FFmpeg always expects -f vob with mpeg2video streams.
    EDIT:
    Wrong!! FFmpeg copies both audio and video with -c copy (never used it that way). Anyways -f vob should be added.
    Weird that a simple copy can cause a buffer underflow error?
    Concatinating vobs from a original dvd works fine. Seems the camera delivers its own mpeg2 format?
    Last edited by Chris K; 15th May 2014 at 14:49. Reason: typo in code c:a should be -c:a
    May 2014
    Planet Earth
    LigH - the problem is I have 800 clips. I have tried many DVD authoring software which cannot handle all these clips. I've made a .txt file which ffmpeg can parse with paths to all the 800 clips. Taking aside the ethics of a DVD being structured, getting all these clips without major errors would be a big hurdle.
    Chris - Thanks. I've tried your command, unfortunately ffmpeg throws up the same errors
    [vob @ 0000000005496900] packet too large, ignoring buffer limits to mux it
    [vob @ 0000000005496900] buffer underflow st=1 bufi=20865 size=32378
    [vob @ 0000000005496900] buffer underflow st=1 bufi=22885 size=32378
    [vob @ 0000000005496900] buffer underflow st=1 bufi=24905 size=32378
    [vob @ 0000000005496900] buffer underflow st=1 bufi=26925 size=32378
    [vob @ 0000000005496900] buffer underflow st=1 bufi=28945 size=32378
    [vob @ 0000000005496900] buffer underflow st=1 bufi=30965 size=32378
    [vob @ 0000000005496900] buffer underflow st=1 bufi=2622 size=96508
    [vob @ 0000000005496900] buffer underflow st=1 bufi=4642 size=96508
    [vob @ 0000000005496900] buffer underflow st=1 bufi=6662 size=96508
  5. Originally Posted by rookieauthor View Post
    You could try to add -bufsize 1835k which is the common buffer size for vobs. I did a experiment by reducing the buffer size and look what I've got...
    [vob @ 02f22d60] buffer underflow st=0 bufi=8065 size=8900
    [vob @ 02f22d60] packet too large, ignoring buffer limits to mux it
    [vob @ 02f22d60] buffer underflow st=0 bufi=8312 size=8900
    If you still got the error, increase (or decrease) the value somewhat. But note that I did the experiment with a regular dvd vob.
    May 2014
    Planet Earth
    Nope still no dice
    [concat @ 0000000002b289a0] Estimating duration from bitrate, this may be inaccurate
    Input #0, concat, from 'd:\video\mylist.txt':
      Duration: 00:00:00.75, start: 0.000000, bitrate: 255 kb/s
        Stream #0:0: Audio: ac3, 48000 Hz, stereo, fltp, 256 kb/s
        Stream #0:1: Video: mpeg2video (Main), yuv420p(tv), 720x576 [SAR 64:45 DAR 1
    6:9], max. 9100 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
    File 'd:\video\output.mpg' already exists. Overwrite ? [y/N]
  7. Originally Posted by rookieauthor View Post
    Nope still no dice
    I don't know what you exactly want to say with this code but you should add -y to the command line to automatically overwrite old exsiting output files. Then the batch would continue. If it is something else, please give more details.
    May 2014
    Planet Earth
    Sorry my bad, I pasted the wrong log. The above is before I press Y, after is still bucket loads of errors per second:
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=53664 size=95551
    [vob @ 000000000562f7a0] packet too large, ignoring buffer limits to mux it
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=55684 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=57704 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=59724 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=61744 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=63764 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=65784 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=67804 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=69824 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=71844 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=73864 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=75884 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=77904 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=79924 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=81944 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=83964 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=85984 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=87986 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=90006 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=92026 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=94046 size=95551
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=510 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=2530 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=4550 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=6570 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=8590 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=10610 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=12630 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=14650 size=33057
    [vob @ 000000000562f7a0] buffer underflow st=1 bufi=16670 size=33057
  9. Originally Posted by rookieauthor View Post
    So don't author it. Just join and encode for DVD compliant MPEG-2 video and whatever audio you're making. Take the elementary streams later and author using Muxman or something.
    DVD "VOB" format
    Video
    Codec: MPEG2
    FPS: 25
    WxD: 720 x 576
    Audio
    Codec: AC3
    Is there a max bitrate being set? I suspect the max video bitrates are too high or ffmpeg doesn't keep to what you set and they spike too high.
  10. It would be interesting to know the gop size of the source clips since the clips are from a camera, not a dvd. MediaInfo can show that.
    Format settings, GOP : M=3, N=12
    Above the gop size of a original dvd vob. I'm not sure but I thought gop size and buffer size are related in some way.
    Aug 2013
    Central Germany
    Which application or device created these clips, you say? With such an amount of errors, I doubt they have ever been DVD Video compliant. There must be a reason why authoring tools would reject them, and even a barely DVD range checking tool like ffmpeg discovers oddities.
  12. Member Cornucopia's Avatar
    Yes, could you put aside Gspot (which hasn't been updated in 7 years) and show us a detailed MediaInfo text readout of one or more of those files? I think that would point to the right solution path.
  13. Analyze video (one of this you trying to concatenate) with ffprobe - i afraid that something is tricky with mpeg2 max bitrate
    @ffprobe -v quiet -pretty -print_format json -show_entries "format=size,bit_rate:frame=coded_picture_number,pkt_pts_time,pkt_pts,pkt_dts_time,pkt_dts,pkt_duration_time,pict_type,interlaced_frame,top_field_first,repeat_pict,width,height,sample_aspect_ratio,display_aspect_ratio,r_frame_rate,avg_frame_rate,time_base,pkt_size" -select_streams v:0 %1 > %1.json
    May 2014
    Planet Earth
    manono - My idea was to re-encode all the clips first. Having never used ffmpeg before, looks like the command I was given in the previous thread copies the streams and no, I didn't add max bitrate, just -bufsize 1835k as Chris advised.
    Scott - See below buddy, takes from the first 3 clips
    General
    Complete name                            : D:\Video\M2U01219.MPG
    Format                                   : MPEG-PS
    File size                                : 5.34 MiB
    Duration                                 : 4s 800ms
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 9 339 Kbps
    Video
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@Main
    Format settings, BVOP                    : Yes
    Format settings, Matrix                  : Custom
    Duration                                 : 4s 720ms
    Bit rate mode                            : Variable
    Bit rate                                 : 8 897 Kbps
    Maximum bit rate                         : 9 100 Kbps
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Frame rate                               : 25.000 fps
    Standard                                 : PAL
    Scan type                                : Interlaced
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.858
    Time code of first frame                 : 00:00:00:00
    Time code source                         : Group of pictures header
    Stream size                              : 5.01 MiB (94%)
    Audio
    ID                                       : 189 (0xBD)-128 (0x80)
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Muxing mode                              : DVD-Video
    Duration                                 : 4s 800ms
    Bit rate mode                            : Constant
    Bit rate                                 : 256 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Delay relative to video                  : -80ms
    Stream size                              : 150 KiB (3%)
    General
    Complete name                            : D:\Video\M2U01220.MPG
    Format                                   : MPEG-PS
    File size                                : 23.6 MiB
    Duration                                 : 21s 120ms
    Overall bit rate                         : 9 384 Kbps
    Video
    Format                                   : MPEG Video
    Duration                                 : 21s 40ms
    Bit rate                                 : 8 941 Kbps
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Standard                                 : PAL
    Bits/(Pixel*Frame)                       : 0.862
    Stream size                              : 22.4 MiB (95%)
    Audio
    Format                                   : AC-3
    Bit rate                                 : 256 Kbps
    Bit depth                                : 16 bits
    Stream size                              : 660 KiB (3%)
    General
    Complete name                            : D:\Video\M2U01221.MPG
    Format                                   : MPEG-PS
    File size                                : 7.72 MiB
    Duration                                 : 7s 200ms
    Overall bit rate                         : 8 993 Kbps
    Video
    Format                                   : MPEG Video
    Duration                                 : 7s 120ms
    Bit rate                                 : 8 558 Kbps
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Standard                                 : PAL
    Bits/(Pixel*Frame)                       : 0.825
    Stream size                              : 7.26 MiB (94%)
    Audio
    Format                                   : AC-3
    Duration                                 : 7s 200ms
    Bit rate                                 : 256 Kbps
    Bit depth                                : 16 bits
    Stream size                              : 225 KiB (3%)
  15. The clip specs look ok! For re-encoding this should already do...
    ffmpeg -f concat -i d:\video\mylist.txt -target pal-dvd -y d:\video\output.mpg
    May 2014
    Planet Earth
    Seems like these clips are cursed I've given the command a go Chris but again constant errors as below:
    [ac3 @ 0000000002a759e0] frame sync error
    Error while decoding stream #0:0: Invalid data found when processing input
  17. Yeah, but this is different. It says ac3 frame sync error.
    To check out if it is the audio that causes the problem you could ad -an to the command line.
    BTW; you need to only post a few lines of the error messages.
  18. Member
    May 2014
    Planet Earth
    Thanks for the continued support Chris. I've added the -an to command line, here is some output
    [concat @ 00000000003188e0] DTS 402479280 < 402480000 out of order
    [concat @ 00000000003188e0] DTS 402994080 < 402994800 out of order
    [concat @ 00000000003188e0] DTS 403768080 < 403768800 out of order
    frame=  119 fps=4.4 q=4.3 size=    3560kB time=00:00:04.68 bitrate=6231.5kbits/s
    [concat @ 00000000003188e0] DTS 406958400 < 406959120 out of order
    [concat @ 00000000003188e0] DTS 409071600 < 409072320 out of order
    [concat @ 00000000003188e0] DTS 409500000 < 409500720 out of order
    The out of order errors appeared 40 times and ffmpeg stopped after the first clip. The output file has no audio when played in VLC
  19. Originally Posted by rookieauthor View Post
    No, -an means "no audio" and was meant for test purpose to see if the errors were only caused by the audio stream. Unfortunately it seems not. I would first try to convert one single clip to see what that does.
    ffmpeg -i d:\video\clip_001.mpg -target pal-dvd -y d:\video\output.mpg
    If that already generates errors you'll have to first find a solution for that.
    FFmpeg has three different concat options. What you now use is called the concat demuxer. It also has a concat protocol (forgot about the third). The protocol is used this way...
    -i concat:clip_001.mpg|clip_002.mpg|clip_003.mpg|... ... and so on.
    There is no option to do this with a text file so it would be hard to try this with 800 clips. You could try it with a few. You have to give the full path.
    http://ffmpeg.mplayerhq.hu/ffmpeg-protocols.html#concat
    May 2014
    Planet Earth
    It seems like we're getting somewhere, the command in your last post converted the first clip without errors.
    I tried this with the second clip and again no errors. Can the above command be tweaked so it gooes through each clip in the .txt file and saves them with the same name into a different folder? If so, they should be easier to concat right?
  21. Originally Posted by rookieauthor View Post
    Yes I think it can with a dos batch file. Not from the text file but directly from the clips folder. But it's way too long ago since I created batch files.
    There are many batch file wizzards here at vhelp and I'm sure someone can post the script for you.
  22. Member
    May 2014
    Planet Earth
    I figured it out. Much of the leg work was done in the previous thread. I copied the complete text file with file paths into an excel spreadsheet. Pasted the data again in the next column. Then copied everything back into the .txt file. Used Notepad++ to do some copy/replacing with the above commands.
    Almost 200 files done in the last couple of minutes. Next question, once all files are done, how do I get ffmpeg to join the lot together?
  23. Member Cornucopia's Avatar
    In that "successful" script you still aren't concatenating, just "re-forming" the data to (hopefully) more strictly follow PAL DVD standards.
    If the result of all this doesn't work, I would suggest you go back to my original suggestion and demux to elementary streams. Then concatenate those, then mux together.
    Or, try concatenating and outputting a TS file, which by its very nature is more capable of handling timing & packet differences. Then you could re-wrap it to a standard Program Stream.
  24. Originally Posted by rookieauthor View Post
    Then I would go back to your first command line...
    ffmpeg -f concat -i d:\video\mylist.txt -c copy -fflags genpts d:\video\output.mpg
    First adapt the list to the new folder if it doesn't use relative paths. Only thing I added is the -fflags genpts command which should rewrite the time stamps from zero on up. This because each single clip starts at zero again. This should avoid seeking problems.
    And then lets hope no new issues arise!
    EDIT: sorry but the command should read -fflags genpts
  25. Member
    May 2014
    Planet Earth
    Scott, I was going through my other thread and saw your post from this morning. I'm sorry I overlooked one of your first posts in my other thread, it wasn't intentional. Anyway I used Chris' command from earlier
    I split the .txt files into 2 to fit each .mpg onto a DVD and now have 2 perfect files which are ready to burn. ffmpeg threw up more errors along the way
    [NULL @ 0000000000338a20] start time for stream 0 is not set in estimate_timings
    _from_pts
    frame=92929 fps=1530 q=-1.0 size= 2966428kB time=01:01:50.55 bitrate=6549.2kbits
    [vob @ 00000000054d66c0] buffer underflow st=1 bufi=721 size=1792
    _from_pts
    [vob @ 00000000054d66c0] Non-monotonous DTS in output stream 0:1; previous: 3346
    78319, current: 334678079; changing to 334678320. This may result in incorrect t
    imestamps in the output file.
    [vob @ 00000000054d66c0] buffer underflow st=1 bufi=1112 size=1792
    _from_pts
        Last message repeated 1 times
    [vob @ 00000000054d66c0] buffer underflow st=1 bufi=478 size=1792
    _from_pts
    [vob @ 00000000054d66c0] buffer underflow st=1 bufi=971 size=1792
    frame=93905 fps=1534 q=-1.0 size= 2997574kB time=01:02:29.43 bitrate=6549.3kbits
    frame=94174 fps=1526 q=-1.0 size= 3006082kB time=01:02:40.19 bitrate=6549.1kbits
    Thanks everyone for all their input
    **Edit**
    Just saw your post Chris, your command above gives the error below
    ffmpeg -f concat -i d:\video\fixed\batch2.txt
     -c copy -genpts d:\video\fixed\part1.mpg
    ffmpeg version N-63128-g0aac9b7 Copyright (c) 2000-2014 the FFmpeg developers
      built on May 13 2014 22:08:26 with gcc 4.8.2 (GCC)
      configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
    isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
    le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
    e --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-
    libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libope
    njpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsox
    r --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab -
    -enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx
    --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxavs --enable-
    libxvid --enable-decklink --enable-zlib
      libavutil      52. 83.100 / 52. 83.100
      libavcodec     55. 61.101 / 55. 61.101
      libavformat    55. 37.102 / 55. 37.102
      libavdevice    55. 13.101 / 55. 13.101
      libavfilter     4.  5.100 /  4.  5.100
      libswscale      2.  6.100 /  2.  6.100
      libswresample   0. 18.100 /  0. 18.100
      libpostproc    52.  3.100 / 52.  3.100
    Unrecognized option 'genpts'.
    Error splitting the argument list: Option not found
  26. Member
    May 2014
    Planet Earth
    double post
  27. Originally Posted by rookieauthor View Post
    I edited the post with a correction on the command. If you encounter seeking issues, consider to redo it with the command.
    EDIT:
    You could try this to get rid of the errors (these still worry me) ...
    ffmpeg -f concat -i d:\video\mylist.txt -c:v copy -c:a copy -bufsize 1835k -fflags genpts -f vob d:\video\output.mpg
  28. Member
    Aug 2013
    Central Germany
    A "buffer underflow" is not a big surprise here: The bitrates of all clips are scratching the DVD Video limits, and a VBV checking multiplexer does much more than just comparing the bitrate — it also tests the usage of an assumed decoder buffer, and this can certainly hit a limit at concatenation points, while there is no issue with the single clips.
    I have some experience from a DVD authoring studio in the past. I have seen clips with single GOP peaks at 13 Mbps being accepted by an authoring tool, and clips with single GOP peaks below 10 Mbps being rejected.
    Your consumer DVD player may or may not choke at these points, depending on the real size of its video buffer (it may be bigger for multi-format players than for legacy pure DVD players). Practice matters.
  29. Originally Posted by LigH.de View Post
    That's indeed what worried me! Also audio sync. I don't know if the OP checked this but concatinating so many clips of only a few seconds long?
  30. Member
    Aug 2013
    Central Germany
    As already said: Better let a specific DVD Authoring tool do this job. But be aware that DVD Video has its limits, regarding a number of cells and chapters per titleset.
    If nothing helps, then a reencode with a good MPEG2 encoder (e.g. HC) and slightly more conservative options (max. 8.5 Mbps) may be necessary.
