Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Hi all , i converted a Mpeg video to some .bmp picture , now i want to convert them to I P B pictures .
    I need a tips or Vc++ code to success it .
    Thank you bro
  2. Member Cornucopia's Avatar
    I-frames are pictures.
    P & B (& D) frames are only PARTLY pictures (they're also partly coded motion vector & concealment info).
    Just how do you intend to SHOW all that?
  3. Use for example mpeg2enc.
  4. Thank for reply
    i use FFdshow to display frame type , it shows I P B frame in an Excel file .
    But i want source code , ffshow is open source code program but it has too many source code on http://sourceforge.net/p/ffdshow-tryout/code/HEAD/tree/
    and i need to find source code for my programs, but many code there , too hard and try to found it Hue hue .
  5. Originally Posted by tranquyettien View Post
    Thank for reply
    This is why i pointed you to mpeg2enc - whis is very basic mpeg encoder and code is not ASM optimized thus is way easier to analyse it and modify or learn.
    For structure analysis just use ffprobe (also open source) with simple comands you can extract all necessary informations about video structure also to csv file.
    @ffprobe -v quiet -pretty -print_format csv -show_entries "format=size,bit_rate:frame=coded_picture_number,pkt_pts_time,pkt_pts,pkt_dts_time,pkt_dts,pkt_duration_time,pict_type,interlaced_frame,top_field_first,repeat_pict,width,height,sample_aspect_ratio,display_aspect_ratio,r_frame_rate,avg_frame_rate,time_base,pkt_size" -select_streams v:0 %1 > %1.csv
    bellow human friendly json
    @ffprobe -v quiet -pretty -print_format json -show_entries "format=size,bit_rate:frame=coded_picture_number,pkt_pts_time,pkt_pts,pkt_dts_time,pkt_dts,pkt_duration_time,pict_type,interlaced_frame,top_field_first,repeat_pict,width,height,sample_aspect_ratio,display_aspect_ratio,r_frame_rate,avg_frame_rate,time_base,pkt_size" -select_streams v:0 %1 > %1.json
