  1. Hello
    I need good software to capture Analog TV programs. Please suggest me a good capturing software.
    I need to capture videos in MPEG2 - DVD quality and MPEG4 - DVD quality and etc.
    I have pixelview Conexant BT878 based PCI card and GADMEI USB TV Card
    i'm using windows 7 and windows xp ....
    thanks
  2. Very difficult to advise something as good software is no longer developed (except vdub) but on your place i would go for:
    http://www.videohelp.com/tools/VirtualVCR (my favourite, have some problems but still one of the best ever tools made for capture)
    http://www.videohelp.com/tools/DScaler (also old one but have very advanced features dedicated to BT/Conexant chips)
    http://www.videohelp.com/tools/Virtualdub (well known and constantly maintained - if it works for you then OK)
  3. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    The only "actual" software is AmarecTV.
    Its work in all HD and Analog cards, olders and news. Its have nice deinterlaced method, suport replay feature using RAM, nice visual and freeware.
    You can record using X264 or lossless codec like UT VIDEO or LAGARITH, after this encode using software like RIPBOT264/VIDCODER/TENCODER/MEGUI
    Get here: http://www.amarectv.com/download/amarectv300c.zip
    Fast tutorial to config AmarecTV: http://www.mediafire.com/view/d0u22pf6vpu4o3w/AmarecTV_RGC_Tutorial_-_Cauptain_2011.pdf
    Aug 2006
    Originally Posted by vidyarathne View Post
    Hello
    thanks
    If you want to run the capture manually, Amarec TV and the other free capture software mentioned so far probably will work, as long as your analog TV card uses software to encode.
    If you need to schedule recordings so you do not need to be present to start the capture, you need PVR software, not ordinary capture software. ChrisTV PVR might be an option (it allows MPEG-2 capture or AVI capture), but it isn't free.
