Results 1 to 10 of 10
  1. I'm wondering if there is an app that i could use to record higher quality videos on my android phone. Think Something like lagarith.
    Thanks for sharing your thoughts and experience
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Higher quality than what? The default app should use the highest quality available with the hardware on the phone.
    Google is your Friend
    Feb 2014
    Mumbai
    What do you mean by higher quality videos?
    The camera is already configured to capture best quality videos..
    as far as Lagarith is concerned, its just a codec to store encode videos losslessly , On an android phone the camera uses a predefined codec (x264 in most cases) , and you cant change that since its embedded into the phone somehow.
    Using lagarith , the video bitrate increases masssively and your phone should be able to write to memory at those high speeds.
    And another thing is you will need a special lagarith encoder designed for use on android platform.
  4. Well i've found little free app called IgCamera, i can record in h264,mpeg4 (3gp or mp4 container) up to 100mbit (haven't tried that high obviously) The pro version has more options
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    It doesn't matter how high a bitrate you can record. The result will be the same, just a bigger file size. There's no free lunch.
    Sony does that kind of crap too. They state 24 megapixel stills from their camcorders, but the sensor is only 1080. They just upsample to 300ppi AFTER capture.
  6. Member Cornucopia's Avatar
    OK this is really weird. I KNOW I posted to this thread (or a near-identical thread) days ago, in fact I even re-edited my post after-the-fact (adding more info). But now, NONE of it is here.
    Suffice to say, you are constrained by the inadequacies of phone hardware & firmware & drivers. This might allow you room to create/use a cam app that has somewhat higher bitrate, or one that allows for semi-manual exposure control, but there are limits to the optics (no existing camera's stock lens is optical-zoom-capable, and both aftermarket retrofits and digital zooms will noticeably reduce quality), there are limits to exposure adjustment (there is no such thing as an f-stop adjustment, it's all as wide-open as possible and adjusted via shutter speed or gain/sensitivity/ISO), and there are limits to data transfer rates (you'd be lucky to record at full "CLASS 10" levels on capable microSD cards). Plus, with such small chipset spaces, you would be in danger of overheating after just a few minutes. Since you are left with such bitrate restrictions (~80Mbps), your best quality option is already your CURRENT option: AVC/h.264 (usually in an MP4 container). It will be hard enough getting one to reliably put out CFR video (as opposed to the usual VFR garbage). I would suggest looking up Cinema FV-5 app, for starters.
    But don't get your hopes up. If you are truly serious about doing good, professional-style video, you will use good, professional equipment. Which (currently), contrary to marketing hype, does NOT include Phones (whether for video or for audio), except as adjunct facilitators/controllers of external hardware.
  7. Member Cornucopia's Avatar
    OK, now I'm starting to wonder what's going on here. Are my posts getting deleted by someone? I can do a VH search on "Cinema FV-5" and see a preview portion of my original post, but when I click the link, it just shows me this current thread WITHOUT my original post!!!
    Baldrick?
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Apple's been running commercials showing a live band using iPhones and iPads as every possible answer to everything A/V, and I guess people buy into that.
  9. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Sorry about that, but I didn't know the correct answer so I stole the jist of your old post and re-worked it into mine. Then reported your post as inappropriate so I guess they auto-deleted it.
    (Just Kidding)
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    Baldrick?
    Yep. It seems to be gone. Google has cached it. I will see if I can find it in the database.
    edit: Nope. It's deleted.
