  1. Hello,
    I have some MPEG-2 video clips that have been edited using Pinnacle Studio 9, and I need to convert them to a format suitable for tablets. I have been advised to go for AVI.
    The point is that when I try "Make Movie" in Studio 9, and select AVI:
    the options given are limited, and the quality of the converted videos is much lower than the original (a huge reduction in quality).
    Could someone kindly advise me on this: is AVI better than MP4 for tablets?
    And, if AVI is the right choice, what would be the best settings.
    The MPEG-2 Files (converted from DVD's VOB files using ffmpeg) have the following values:
    Video:
    size 720 x 576 (3/4)
    frame rate: 25
    bit rate: 4000 kbps (variable)
    Audio:
    MPEG Layer II
    Channel: Stereo
    Bit Rate: 192 kbps
    Sample Rate: 48 KHz
    In Studio 9, when selecting AVI, the values given are:-
    VIDEO
    Compression: PICVideo MJPEG Compressor
    Width: 720
    Height: 576
    Frames/Second 25
    AUDIO
    Type:PCM
    Channels: 16-bit stereo
    Sample Rate: 48kHz
    Thank you in advance,
    David
    Last edited by tetrahall; 5th May 2014 at 00:12. Reason: correcting a typing mistake
  2. '
    i use FREESTUDIO's 'Free MP4 Video Converter'
    i use it to convert edited .ts files (using Avidemux)
    and it does well for my apple devices
    .ts = transport stream (recorded TV shows, edited to remove commercials)
    been doing it that way for years now
  3. Thank you for your reply. I am downloading "Free Studio" and will give it a try.
    But is AVI the right format for tablets (using Windows)?
    I would appreciate some guidance here. Thanks!
    Or just get VLC media player for your android or ios tablets. It can play most formats directly.
    But if you want to shrink then convert to MP4/M4V (with h264 video and aac audio) using for example handbrake, vidcoder, xmedia recode. No annoying adware like the freestudio installation...
    Don't use any avi format.
  5. Many thanks for the information.
    I will try these now.
