Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Hi,
    Currently, I am trying to write a code that takes Mp4 video files and can create gifs from it. I am doing it just for fun.
    I was wondering how on a MP4 file format I can extract the following information:
    1. Width/Height of the video file
    2. RBC Color Space
    3. Image JIF
    I am not sure if this is the right place for the thread but it is worth a shot to see what people think.
  2. MP4 file format specification preview:
    http://webstore.iec.ch/preview/info_isoiec14496-14%7Bed1.0%7Den.pdf
    The full document costs about US$100.
  3. Member bat999's Avatar
    Feb 2008
    Aug 2013
    Central Germany
    I believe MediaInfo will even return only specific values if you use special command line options. I just don't know right now where to find the table...
    Another chance will be tools in the GPAC package, like MP4Box.
    Sep 2012
    Australia
    Define code?
    The mediainfo dll is free, and simple enough that even I can access it... Assuming you're using an actual Programming Language and not a script.
    -edit- How will you be decoding the images? I doubt you'll be writing your own codecs... DirectShow, or whatever it's called now-a-days?
    Aug 2013
    Central Germany
    To be able to read a video frame, you may possibly use libav libraries in your application. They contain functions to open the MP4 container, read attributes, and decode the contained video stream. I wonder if ffmpeg can already do most of the desired functionality. At least it will be able to extract frames to images, I just doubt it will write (animated?) GIFs.
  7. Member Cornucopia's Avatar
    I hope you aren't doing this to just re-invent the wheel, because Virtualdub - with an MP4 input plugin - can already output to GIFs.
