Results 1 to 9 of 9
    May 2014
    Dubai
    I have a Samsung Blu-Ray Player BD-D5900. I insert my 1 TB HDD and play MKV video files and the files work perfectly but the problem is that it won't play along with the subtitles embedded with it. Please help me out with playing the subs along with the video.
    canada
    Have tried playing the mkv with the sub as a separate file with the exact same name as the video?
    May 2014
    Dubai
    Yes, but I actually wanted to try with the internal subs, any idea.
    Aug 2006
    I think you are out of luck. I cannot recall seeing any Blu-Ray players (or any hardware-based media players for that matter) which can play internal subtitles from .mkv files. Support for internal subtitles in .mkv files only seems to be common with software media players for computers.
    canada
    My sony bdp-s380 plays mkv with merged subs but doesn't play them separately.
    Aug 2006
    Then, the OP needs to buy the same Blu-Ray player that you have, since his can only play external subs. Problem solved.
    canada
    Or bring the disc/usb to a local store and see what other player can read muxed subs.
    May 2014
    Dubai
    Ok anyways can I extract those subs from the file ?
    canada
