Results 1 to 9 of 9
    Mar 2014
    US
    The installable version has a bunch of adware (scanned on virustotal.com). The portable version scanned as having Packed.Win32.Katusha.1!O, but it only came up positive on 1/51 scanners.
    Does anyone have additional thoughts on the likelihood of a false-positive? or on the overall reputability of the program (the portable version in particular)?
    Or perhaps a better recommendation? I tried using MP4Box to extract original audio from MP4s, but it's kind of annoying checking multiple boxes on batch extractions.
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I have it and no adware on my install - malware bytes, avg and hijackthis finds nothing.
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
    Mar 2014
    US
    Portable or full install?
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Full installation
  5. Member ozok's Avatar
    Oct 2011
    Turkey
    My avira antivirus also reports a virus. It's TR/Spy.11151 in CTAAEncoder.exe, not program itself. I'll send a mail to author of this program. It might be a false-positive.
    Edit: I think program doesn't have an installer.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Attached contents of Pazera install folder - inside the tools only ffmpeg and mediainfo. The file CTAAEncoder.exe is not in my install and there is an uninstaller.
    Image Attached Images
  7. Member ozok's Avatar
    Oct 2011
    Turkey
    You are right there is an installer version. I had downloaded the file from a different site which does not include ad-supported versions of some software. I've downloaded the installer and it looks like it includes adware which doesn't mean it's infected. There is some information about it in their site: http://www.pazera-software.com/privacy/
  8. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I tend to download from videohelp tools section and always use custom install if it is presented in the installation process.
    Mar 2014
    US
    I scanned (virustotal) the videohelp downloads (portable and non) and they are completely clean, whereas the install download from pazera-software.com has 10 hits on virustotal, and even the portable one got a hit.
