Results 1 to 11 of 11
    Jan 2012
    Budapest
    HI!
    Do you know softwares, which can use DGAVCDec (Donald Graft) decoder/frameserver as video input during their video transcoding?
    Thank you for your reply!
  2. Originally Posted by Stears555 View Post
    HI!
    Any program that can accept avisynth as input . (Too numerous to list)
    Or you can use avisynth virtual frameserver (avfs) as a workaround (it makes a "dummy" or fake AVI).
    So basically any software if you use that workaround
    But DGAVCDec is depreciated (it has problems with some streams), no longer developed, and the author has withdrawn support
    Jan 2012
    Budapest
    HI!
    And how can I detect that DGAVCDec is really active during the transcode process?
  4. Originally Posted by Stears555 View Post
    In avisynth , if you use AVCSource() as the source filter , it calls DGAVCDecode.dll directly.
    Jan 2012
    Budapest
    Forexample, what can I do in megui? There are an option for DGAVCDec, but I don't see any activity on my GPU-meter.
    I haven't DGAVCDecode.dll, I have only DGDecodeNV.dll
  6. DGAVCDec doesn't use GPU. CPU only
    It's not the same thing as
    http://neuron2.net/dgdecnv/dgdecnv.html
    You need a license (not free)
  7. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    You even have the link to download page in your last post:
    http://www.videohelp.com/tools/DGAVCDec
    (direct link: http://www.videohelp.com/download/dgavcdec109.zip )
    With NV version, you are limited to use it on a PC with Nvidia card, then it's preferable (speed-wise + unlike basic version, it properly works with MBAFF stream type which occur in 5-10% of cases).
  8. Originally Posted by Stears555 View Post
    For MeGUI, DGAVCDecode.dll should be located in the "MeGUI\tools\dgavcindex" folder.
    DGDecodeNV.dll is located in the "MeGUI\tools\dgindexnv" folder.
    Jan 2012
    Budapest
    Hello!
    Here is the result ((
    I can not chose DGindexNV (((
  10. Originally Posted by Stears555 View Post
    options => settings => external configuration tab => enable DGIndexNV => save
    Jan 2012
    Budapest
    When I opened that panel, the settings were the same as your suggestion. But it couldn't help
