Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
    Mar 2004
    San Diego, CA
    I usually have good luck splitting multi-episodes but I seem to be having issue with one for the first time.
    I have a dual-episode MKV that wont split properly. Total time is 00:21:56 (mediainfo reads 00:21:57)
    The first segment ends at 00:11:11 and when trying to use this number in mkvtoolnix, it outputs clip at 00:11:17
    Now if I try going to lower "seconds" I either stay the same result or end up at 00:11:06 as the output clip.
    I have even tried adjusting milliseconds 00:11:11.000000000 but still not getting the clip to end at the right time.
    Should I be trying another piece of software ?
  2. The short explanation is mkvmerge isn't frame accurate for cuts. You can only cut on GOP (group of pictures) boundaries.
    You need a smart rendering editor to be frame accurate. It will re-encode the few frames of the GOP within the cutsite.
    The only free one is mkvcutter by selur.
    http://forum.selur.de/topic220-mkv-cutter-tool-to-cut-h264-mkv-files-frame-accurate.html
    Retail ones include videoredo, solveigmm video splitter, tmpgenc smart renderer
    Mar 2004
    San Diego, CA
    Thanks for the help Will see what I can do.
    Mar 2004
    San Diego, CA
    Tried mkvcutter but still getting same result of 00:11:17
    Episode ends at frame 16088 so tried that but result was same as usual and so I tried 16085 down to 16080 but still wants to end 6 seconds too late.
    Suggested key frame is 15975 so tried that and it ended the clip 5 seconds too short.
    Guess episode will have to stay as is ...
  5. tsMuxer used to have a cutter in it. Not sure how good it is. Not used it since before it started being updated again.
    You might try that and remux back to MKV.
    Mar 2004
    San Diego, CA
    tsMuxer did a better job for the first clip. Starting and ending spot on. Unfortunately I cant get the second clip to start at the right place.
    I went back to mkvtoolnix but no luck there for the second part. It's plus or minus 5 seconds no matter what.
    canada
    You have to use a video editor that will re-encode the seconds where you want to edit and leave the rest of the video untouched.There are members here who will recommend a program that can do this.
  8. Before you go the whole hog with a video editor you could also try SolveigMM AVI Trimmer + MKV (not frame accurate) and
    http://forum.videohelp.com/threads/354976-How-to-cut-any-video-with-the-free-Video-to-...ideo-Converter
    again, not frame accurate but you never know your luck
