    Mar 2011
    Oregon, US
    I have a 1hour 45 minute video file(AVI) that is full of 7-7:30 minute videos. I would like to cut this file into its constituent parts, but I don't know what I am looking for. I would like to find something that would let me manually jump ahead and cut at ambiguous points of the file then save them in mpeg4 or mpg files. What is this piece of software called? Can u recommend a freeware piece of software that allows me to do this? Thankyou John
  2. Try VirtualDub. Use Video -> Direct Stream Copy mode. Mark-in, mark-out, Save. Repeat for each clip. That will give you a bunch of AVI clips.
    Mar 2011
    Oregon, US
    Does that allow you to skip ahead in the clip and cut then go ahead and cut again and so forth, then allows you to save the clips? John
  4. Mark-in, mark-out, save. Mark-in, mark-out, save. Mark-in, mark-out, save...
  5. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    RBCC, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
