Results 1 to 11 of 11
  1. Novice
    Apr 2014
    I have this MP4 and MKV DVD rip of a 20 minute episode (which I already own) that someone else made. Here is what VLC says about both of these files.
    The file name mentions x264 and Nero AAC. Is Nero AAC different from regular AAC, which my Blu-ray player supports? Could this be a reason why my Blu-ray player won't play the files? Here is the manual page that lists which formats it can playback.
Name:	LG Blu-ray Formats.PNG
    I'm having difficulty making sense of all this. If uploading the file will help, I can do that, but I will delete it until my problem is resolved. Thanks!
  2. nero is just the brand of aac encoder; it won't affect compatibility
    Possibly those Russian? characters in the filename are giving your hardware a difficult time. Try renaming the file to something simple and English, with short length. e.g. "video.mp4"
    If that still doesn't work use mediainfo(view=>text) on the problematic file , copy & paste the results back here
    http://www.videohelp.com/tools/MediaInfo
  3. Novice
    Apr 2014
    Here are the results:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 174 MiB
    Duration : 21mn 17s
    Overall bit rate : 1 143 Kbps
    Encoded date : UTC 2007-12-03 11:38:32
    Tagged date : UTC 2007-12-03 11:38:32
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 13 frames
    Codec ID : avc1
    Duration : 21mn 17s
    Bit rate : 942 Kbps
    Maximum bit rate : 3 795 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Original display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.091
    Stream size : 143 MiB (82%)
    Title : Video
    Writing library : x264 core 57 svn-700
    Encoding settings : cabac=1 / ref=10 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=942 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
    Tagged date : UTC 2007-12-03 11:40:06
    Audio #1
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 21mn 17s
    Bit rate mode : Variable
    Bit rate : 96.0 Kbps
    Maximum bit rate : 109 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 14.5 MiB (8%)
    Title : Russian
    Language : Russian
    Encoded date : UTC 2007-12-03 11:40:03
    Audio #2
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 21mn 17s
    Bit rate : 100 Kbps
    Maximum bit rate : 108 Kbps
    Sampling rate : 48.0 KHz
    Stream size : 15.3 MiB (9%)
    Title : English
    Language : English
    Encoded date : UTC 2007-12-03 11:40:04
  4. The problem is the encoding settings used
    Most current hardware devices are limited to High@L4.1 . That file is High@L5.1 , and too many reference frames
    Sometimes you can patch the level to "fool" the hardware. e.g. using various level editors (h264 level editor) , but if the file uses actual references that high, it wont work
    http://www.videohelp.com/tools/H264-AVC-Level-Editor
  5. Novice
    Apr 2014
    Here are the results for the MKV as well.
    Format : Matroska
    Format version : Version 1
    File size : 159 MiB
    Duration : 21mn 16s
    Overall bit rate : 1 044 Kbps
    Encoded date : UTC 2008-06-09 15:28:23
    Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format settings, ReFrames : 10 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 21mn 16s
    Nominal bit rate : 936 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Original display aspect ratio : 3:2
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.090
    Title : Eng. Video
    Writing library : x264 core 59 r859M ce13bb6
    Encoding settings : cabac=1 / ref=10 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / fgo=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=936 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 21mn 16s
    Title : Eng. Audio
    Language : English
    Default : Yes
    Forced : No
  6. Novice
    Apr 2014
    Most current hardware devices are limited to High@L4.1 . That file is High@L5 , and too many reference frames
    Do you think the files can play on a PlayStation 3 instead? That's the only other thing I have.
  7. Same issue with the MKV . Most current devices won't play High@L5.1 , even if they conform to specs that are lower. The presense of that very "label" prevents playback
    Nope , It won't play on a PS3
    You can try that level editor (probably won't work , but worth a try) , otherwise you have to re-encode the files with compliant settings
  8. Novice
    Apr 2014
    Changing the level worked! I was just going to end up connecting my laptop to my T.V. and watch them that way. Thank you so much for your help!
  9. Novice
    Apr 2014
    By the way, I changed the level to 1. What's the best level to choose?
  10. Probably High@L4.1 - that's the cut off for most devices
    It doesn't always work, but it's worth a try (saves you the time and quality loss from reencoding)
  11. Novice
    Apr 2014
    Thank you again for your help!
