Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    I'm at the bottom of a 50pk of Optical Quantum OQBDR04LT-50 4X BD-R discs where you see the loose round plastic divider/protector. There are two BD-R LTH discs being used as that divider, followed by an actual plastic divider.
    Are these LTH discs so undesirable that the manufacturer sees them fit as packaging material?
    Disc ID: UMEBDR-114-000 which I searched but cannot find
    EDIT:
    I just answered my own question. ImgBurn has encountered a I/O Error, which makes this my first bad BD-R burn in over 2 years. Case closed.
    -The Mang
  2. Member turk690's Avatar
    Jul 2003
    ON, Canada
    Maybe for that manufacturer. But I routinely use Verbatim LTH BD-Rs (J-BDR-25WS-25SB6L) because for one these have a waterproof glossy inkjet label and so far no-one I gave them to has had problems playing them back.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
    I've literally use bad discs for quick/temp drink coasters.
    Covering the hole is the only problem.
