Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. The problem I'm having is a single video file I recorded is becoming Desynched after throwing it thru any video editor that can actually read the original video file.
    The original video file is a .ts file (using MPEG-derivative codec) which I use VSDC Free Video Converter to covert to .avi/.mpeg/.mp4. (The VSDC program seems to be the only one that can open up and read the video file aside from Media Player Classic) VirtualDubMod refuses to open it due to it supposibly not an MPEG-compliant codec, even though MPC claims the video its decoding is MPEG). And Windows Live Movie Maker can open it, but can't read the video segments.
    Anyways when I convert the files, either as a single 3~4 hour long file, or segment it into various sections, The beginning and end of the files is okay, no lip synch issues, but the middle segments, the audio can be 5+ seconds off.
  2. It's a MPEG2 transport stream , but what is the video codec ? Use mediainfo (view=>text) . You can copy & paste the results back here
    What is the source? Often transport streams have discontinunities, other stream errors when capped or trasmitted (sat, cable) . Sometimes you can repair them with projectx, tsdoctor
    Other free programs that should be able to open the original , and edit or convert it include avidemux, aviutl, vdub with the ffinputdriver
  3. It's from a VHS over Composite line.
    General
    Complete name                            : ...\Composite_20140403_1921.ts
    Format                                   : MPEG-TS
    File size                                : 7.55 GiB
    Duration                                 : 3h 1mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 5 943 Kbps
    Video
    Menu ID                                  : 1 (0x1)
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@Main
    Format settings, BVOP                    : No
    Format settings, Matrix                  : Custom
    Format settings, GOP                     : N=15
    Codec ID                                 : 2
    Duration                                 : 3h 1mn
    Bit rate mode                            : Variable
    Bit rate                                 : 5 261 Kbps
    Maximum bit rate                         : 6 500 Kbps
    Width                                    : 720 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 29.970 fps
    Standard                                 : NTSC
    Scan type                                : Interlaced
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.508
    Time code of first frame                 : 00:00:37;00
    Time code source                         : Group of pictures header
    Stream size                              : 6.68 GiB (89%)
    Audio
    Menu ID                                  : 1 (0x1)
    Format                                   : MPEG Audio
    Format version                           : Version 1
    Format profile                           : Layer 2
    Codec ID                                 : 3
    Duration                                 : 3h 1mn
    Bit rate mode                            : Constant
    Bit rate                                 : 384 Kbps
    Sampling rate                            : 48.0 KHz
    Delay relative to video                  : -154ms
    Stream size                              : 499 MiB (6%)
    Menu
    Menu ID                                  : 1 (0x1)
    Duration                                 : 3h 1mn
    List                                     : 1001 (0x3E9) (MPEG Video) / 1002 (0x3EA) (MPEG Audio) / 1003 (0x3EB) ()
