Results 1 to 10 of 10
  1. When using ffmpeg to transcode large MKV files to smaller MP4 files to play on my phone, there appears in some of the outputted files a footer reading "00:00:00:000" at the bottom of my screen. Oddly, it's visible in Media Player Classic but not Windows Media Player. Is there a command line switch that will prevent ffmpeg from putting this information or instruction in the new file? Thanks.
  2. Originally Posted by wallywalters View Post
    If it's a sub, add "-sn" to the commandline (without the quotes)
    You can do a quick verification test by encoding , say a 10 second section then playing that back. Add "-t 00:00:10" to the commandline (without the quotes)
    Make sure you move the file , change the name of the file, or that other sub files are not in the same directory (MPCHC might be reading other soft subs in the same directory)
  3. Thanks. Still getting the same results, though. I have also tried it with and without "-metadata timecode= " to no avail.
  4. But you say it's only on some of the output videos ?
    Can use use mediainfo (view=>text) and determine what is different for those source videos that have the problem ?
    Can you post your commandline and maybe a sample that exhibits this problem ?
    Does the "footer" change, like timecode, and is it persistent? Or only at the beginning ? Or only the "00:00:00:000" entry ?
  5. Thanks again. Now we're getting somewhere. I just compared two files -- one with the footer and one without -- and the information below is only in the MediaInfo report of the one with the footer, so it's these "menu" listings that are the problem. The question now is what's the CLI switch to keep them out of the output files?
    Menu #1
    Codec ID : text
    Duration : 1mn 0s
    Language : English
    Menu #2
    00:00:00.000 : 00:00:00.000
  6. So that was the input file ? What does mediainfo say about that output file?
    What is your current commandline ? If you didn't specify copy all streams -c copy -map 0 , it shouldn't have been copied over
    ie. If you only specified video and audio, that's what you should be getting; the other stuff should be dropped
  7. My command line is: "%ffPath%\ffmpeg.exe" -threads 4 -y -i "%~nx1" -f mp4 -sn -c:v libx264 -r:v 23.976 -vf scale=720:404 -aspect 2.35 -crf 19 -coder 1 -c:a libvo_aacenc -b:a 96k -ar 48000 -ac 2 -t 0:01:00 "%~n1 (NEW).mp4"
    As for the MediaInfo report on the input file, this notation appears below the audio section (and it's the only entry that isn't in the MediaInfo report on the input file that doesn't produce the footer):
    Menu
    00:00:00.000 : en:00:00:00.000
    Should I be looking at the "map" switch to ignore the item called "Menu?"
  8. I'm not sure . Does the menu show up as a separate stream in ffmpeg or ffprobe ?
    eg.
    ffmpeg -i input.ext
    It will say something like
    Stream
    0:0 video
    0:1 audio
    You can try adding -map 0:0 -map 0:1 to specifically call the 1st video, 1st audio stream
  9. ok add
    -map_chapters -1
    This worked on a couple test videos I had. If it doesn't work for you, please post an input sample
  10. That did it. Thank you very much. The way I was going, I never would have found that on my own.
