Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. i installed bd rebuilder and all the other stuff that it requires but when i start it up it says i need ffdshow installed for program to run i have ffdshow installed i've uninstalled and re downloaded it but still have same problem any help would be appreciated thanks
    Nov 2003
    West Texas
    Did you install the version of ffdshow that is available at the BD Rebuilder page at doom9? http://forum.doom9.org/showthread.php?t=143716
  3. yes i did
    Nov 2003
    West Texas
    Does ffdshow install correctly (as far as you can tell) and allow you to set filters as needed for BD Rebuilder?
    If using Windows 7 or 8, have you tried running BD Rebuilder as administrator (right click on the executable to get this option). Do you see the error when running Help-->Inspect within BD Rebuilder?
    I hate recommending registry cleaners, but you might want to try CCCleaner after uninstalling ffdshow. Manually remove any folders that were created when installing ffdshow. Then reinstall ffdshow again.
