Not quite sure about this one, so after some help.
I have two programmes that output video/visual media. These are Virtual DJ and Screen Monkey.
What I would like to happen is that I can have a video playing on Virtual DJ and then when I load up a picture or other video file in Screen Monkey, that the Screen Monkey visual comes to the front. What happens at the moment, is that you can only see what is displayed on Screen Monkey when Virtual DJ is not playing.
Any suggestions on a setting of either of these programmes would be good. Or if there is software available that allows you 'vision mix' the output of two programmes running on your screen.
It is a windows based PC.
Many thanks!
