    Apr 2014
    South Dakota
    Hi, I recently downloaded Avidemux and have been trying it out, but ran into a glitch. It's an AVI video. I was able to cut part of the vid just fine, but when I tried using the filters it won't save. Just tweaked the vid a little to make it darker, but the Filter Manager window won't go away so I can save, thus my tweaking is to no avail. I have video and audio output set at "Copy" and "Output Format" set to AVI Muxer . Then I do my filter change and then "preview" and OK, but the Filter Manager remains. If I click "close" the video isn't changed. I tried "Save Filters" and "Load Filters", but that also doesn't work. What am I doing wrong?
    Thanks, Pat
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You can't use "Copy" after changing/filtering the video.
    Apr 2014
    South Dakota
    Soooo what do I use? I tried about 4 options, but none worked. Think I'll reinstall.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If you insist.
  5. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    You need to re-encode any time you do filtering. Copy won't work. It's only for cuts and pastes with no change in the video structure.
