    Apr 2014
    Ashtead, UK
    Hi - new user here
    Tried to split a 3 hour movie (mkv) into 3 pieces and selected link video for the same time codes for the subtitle file. Specifying the break point as 3550s (econds) in the global tab and selecting link resulted in files which appeared to be a mixture of video segments always starting with the beginning of the master file.
    The fix I found was to specify the file size rather than the time then the function worked perfectly.
    Hope this helps some else
    Best Regards
    pbraine
  2. Member DB83's Avatar
    Jul 2007
    You appear to have left out some vital information.
    What program/utility are you referring to ?
    Apr 2014
    Ashtead, UK
    oops! my aplologies.
    Software - MKVToolnix 6.8.0 which is displayed as mkvmerge GUI on my desktop.
    my bad
    best regards
    pbraine
