Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 30 of 38
  1. I was given a click by click method using ffmpeg to download pbs videos. I will later post this method with screenshots for anybody who is interested.
    For now, I am using this command:
    ffmpeg -i http://ga.video.cdn.pbs.org/videos/nature/e1a35d94-fd17-4615-99c3-f22db7f5cc41/123507/hd-mezzanine-16x9/naat-mybionicpet-0516x9-16x9-hls-64-800k.m3u8 -vcodec copy -acodec copy -bsf:a aac_adtstoasc pbsvideo.mp4
    When I pasted this into ffmpeg, it downloaded the video.
    (See screenshot.)
    I have experimented around with this method, and it takes about 2 hours to download a one hour video. You can see in the screenshot that it is converting at 13fps.
    My question is this: Why does it need to convert? I just want to download the video, and it seems that should not involve converting. If I use Internet Download Manager, a 1 hour pbs video will download in 10 minutes, while this ffmpeg method takes 2 hours. Is there a way to use ffmpeg to download in a shorter time? If so, what would the above command be?
  2. Former Member
    Dec 2007
    In the other pbs thread, in post #11, it was explained how to adjust the m3u8 url to the direct mp4 url. From post #11;
    or you can download it directly from site just change hls-800k.m3u8 to mp4-800k.mp4
    The direct mp4 url will almost always download faster, especially using a download manager/helper/extension, compared to using ffmpeg.
    If you need a really easy way to download from pbs, install firefox without flash (or uninstall flash for firefox). Then, various extensions (or IDM) will detect the direct mp4 link when you load the pbs page. It will be loaded as html5 video rather than flash video, although the video might not play - the mp4 link will still be detected.
  3. I understand about the method you described (ie just change hls-800k.m3u8 to mp4-800k.mp4).
    I just wanted to use ffmpeg to get some experience with it.
    Can you explain in more detail the above? Preferably with screenshots. I'm not sure what you mean about "flash". Which one do I uninstall? How do I uninstall it? See 2 screenshots. Is it possible to just choose "never activate" in red circle? Since Adobe Flash is commonly used, I would like a simple way to reinstall it. What extensions will detect the direct mp4 link? I prefer not to use IDM. If you could provide click by click details, that would be useful.
  4. Former Member
    Dec 2007
    You probably shouldn't uninstall flash if you haven't any experience with doing so. It appears that your OS is XP. Flash is installed separately for IE (that is the reference to ActiveX in Add/Remove Programs) and other browsers. You could just disable flash in firefox via the interface in your screenshot.
  5. THANK YOU VERY MUCH. I was able to download 2 different pbs videos from the information you provided. No software needed, no dos window, no ffmpeg, no user agents, no iPhones, no ad blockers, no extensions, no addons needed.
    How to do:
    1) On Firefox, go to Tools>addons>plugins> Shockwave Flash
    and change from" Always Activate "to "Never Activate" (see screenshot 1 , red circle).
    2) Go to pbs website and choose video. When you get the "play arrow", right click on it and choose "copy link location".
    (See screenshot 2).
    3) Paste the link into notepad. In my case the link is:
    http://ga.video.cdn.pbs.org/videos/newshour/0eb2e451-70d0-48f3-912e-b9cc56f6d4dd/127210/hd-mezzanine-16x9/pnwe000164_forweb-16x9-mp4-baseline.mp4
    You can paste this link directly into Foxfire to download.
    You can also change the word "baseline" near the end of the link into "400k" or "800k".
    So the modified link becomes (using "400k"):
    http://ga.video.cdn.pbs.org/videos/newshour/0eb2e451-70d0-48f3-912e-b9cc56f6d4dd/127210/hd-mezzanine-16x9/pnwe000164_forweb-16x9-mp4-400k.mp4
    Using "400k" or "800k" in this case gave a bigger file size. (60mb vs 83mb vs 173mb for a 30 minute program).
    I suppose it is good to have 3 different links, in case one of them doesn't work.
    I do have a question: will this method (disabling Flash) work on any other websites besides pbs?
  6. Former Member
    Dec 2007
    Yes, it will work for some other sites that I can't think of at the moment.
  7. Do you know if there is any way to get/extract/capture the closed captions (cc) on the pbs videos?
  8. Former Member
    Dec 2007
    Search the page source for the dfxp file.
    http://ga.video.cdn.pbs.org/captions/newshour/d0676e24-cfe1-441a-ac28-9660dfa38c32/captions/235237_Encoded.dfxp
  9. Can you explain in more detail with a screenshot how you got the above url for a given video? What do you mean by "page source"? I put the url into firefox and it downloaded a 252kb dfxp file.
    EDIT: It appears that the dfxp file that I downloaded from your above url can be converted to srt with Subtitle Edit. But something doesn't seem right.
    Here is an excerpt of the srt file:
    1
    00:00:11,999 --> 00:00:12,999
    DECADES OF SECRECY, MEDICARE
    UNVEILED WHAT IT PAYS INDIVIDUAL
    DOCTORS.
    2
    00:00:12,999 --> 00:00:14,999
    DOCTORS.
    AND THE DATA SHOWS A TINY
    3
    00:00:14,999 --> 00:00:15,999
    DOCTORS.
    FRACTION OF PHYSICIANS EACH
    4
    00:00:15,999 --> 00:00:17,999
    RECEIVED MILLIONS IN A SINGLE
    5
    00:00:17,999 --> 00:00:17,999
    YEAR.
  10. Former Member
    Dec 2007
    I'm not sure why it is doubled-up like that.
    The subs for the recent episode of 'Ask This Old House' seem ok;
    http://ga.video.cdn.pbs.org/captions/old-house/4d84ebb1-bbc1-42a8-9221-11e3a9bca852/captions/235329_Encoded.dfxp
  11. The dfxp subtitle file that you just sent (you said "Ask This Old House") seems fine when converted with Subtitle Edit. Can you tell me in more detail how you get the dfxp file? A screenshot would be helpful.
    Excerpt of srt file:
    1
    00:00:04,999 --> 00:00:07,999
    KEVIN: Today on
    "Ask This Old House"...
    2
    00:00:07,999 --> 00:00:09,999
    We'll show you how to build
    a simple table
    3
    00:00:09,999 --> 00:00:12,999
    and how to finish it
    the right way.
    4
    00:00:12,999 --> 00:00:15,999
    MAN: And you can see
    that our top portion,
    5
    closest to us...nice and even.
    6
    00:00:17,999 --> 00:00:19,999
    KEVIN: Look at the blotchiness
    that we've got down there.
    7
    00:00:19,999 --> 00:00:20,999
    MAN: Look at the blotchiness
    we're getting down there.
    8
    00:00:20,999 --> 00:00:22,999
    When you cut down a tree,
  12. Former Member
    Dec 2007
    An easier way than tracing through the source paths is just to use the video ID# with videoInfo.
    So, for example, if the video url is;
    http://video.pbs.org/video/2365222277/
    Take the video ID# (2365222277) and use it with the videoInfo page;
    http://video.pbs.org/videoInfo/2365222277/
    Load the videoInfo page. The captions url is near the bottom of the page.
  13. I would like to know how you knew that adding the word "Info" to
    http://video.pbs.org/video/2365222277/ ie http://video.pbs.org/videoInfo/2365222277/
    would get a whole new page of detailed info, including the subtitles url. Do you work for pbs? Does this method work for other websites?
    At any rate, I want to add some instructions for anybody else looking for subtitles on pbs videos.
    1) Go to pbs website and choose a video ( screenshot1, red circle). Shortly after you click on the video, a number will appear on the url at the top (green circle). Copy the whole url, in this case:
    http://video.pbs.org/video/2365216243/
    2) Paste this url into notepad and add "Info" (note capital I) so that you have
    http://video.pbs.org/videoInfo/2365216243/
    3) Paste this into Firefox and get a page full of info. The subtitle url is in the middle (see screenshot2) after
    the words "closed captions url".
    In this case the subtitles url is:
    http://ga.video.cdn.pbs.org/captions/old-house/e533a42b-0bbc-4257-8ea0-24a7b6ded0f3/ca...2_Encoded.dfxp
    4) Put this url into Firefox and download the dfxp file.
    5) Input this into Subtitle Edit and save as subrip (srt).
  14. Originally Posted by jimdagys View Post
    How to do:
    (See screenshot 2).
    I tried to do the shockwave tip you suggested.
    I keep getting the error
    Error loading player:
    No playable sources found
    What could I be doing wrong? I am using FF latest version and windows 8.
    I was able to see the other front line someone else posted and use download helper to obtain the link. I am trying to get this link below.
    http://video.pbs.org/video/2365207128/
  15. Former Member
    Dec 2007
    Originally Posted by pbshelp View Post
    ...tried to do the shockwave tip...
    ...I am trying to get this link below.
    The link can also be obtained from the redirect link in the info page, as noted earlier in this thread.
    So, for the video you asked about (2365207128), the redirect from the info page is;
    http://urs.pbs.org/redirect/61d86ebb811c4b1bb128199400c20526/?format=jsonp&callback=jQuery
    Load the redirect and change the result for better quality (if desired), as noted earlier in this thread.
    Also, if needed, subtitle link;
    http://ga.video.cdn.pbs.org/captions/frontline/ef468623-4c4b-4a47-a317-ba1ed38fddde/captions/143342_Encoded.srt
  16. Questions for Blimey:
    In the above post, we are talking about the link:
    Question #1:
    So in this case, is the info page:
    http://video.pbs.org/videoInfo/2365207128/
    Is this correct?
    Question #2
    You said you could get the following url from info page:
    However, I could only find this (ie. does not have appended (?format=jsonp&callback=jQuery) on that info page:
    So. how did you get the whole url that ends in "jQuery"?
  17. Former Member
    Dec 2007
    That is the correct video and its corresponding info page. You can use the redirect url exactly as it is found on the info page. The additional parameters were used in the reply for illustrative purposes only --- so that the url wouldn't immediately redirect and its output could be more easily seen on screen. But nothing is required beyond the url exactly as it occurs on the info page.
  18. Member
    Jul 2014
    Australia
    Hi folks, Im new to the site and was following this thread. I was looking for closed captions for the movie below;
    http://video.pbs.org/video/2365206680/
    Everything was fine, but the subtitles appear to be out of sequence and sometimes truncated.
    Would like to know how to correct it. Is there any other place where I can find subtitles for this movie?
    Below and excerpt of the subtitles:
    1
    00:00:07,999 --> 00:00:07,999
    2
    00:00:07,999 --> 00:00:08,999
    THIS WEEK ON
    3
    00:00:08,999 --> 00:00:09,999
    LOCAL, USA
    4
    00:00:09,999 --> 00:00:10,999
    5
    00:00:10,999 --> 00:00:12,999
    PORTRAITS OF THE HUNGRY IN
    6
    00:00:12,999 --> 00:00:13,999
    AMERICA.
    7
    00:00:13,999 --> 00:00:14,999
    MEET FARMERS
    8
    WHO CAN'T GET
    9
    00:00:15,999 --> 00:00:15,999
    ENOUGH TO EAT.
    10
    >> OUR FREEZER IS
    11
    TOTALLY
    12
    00:00:17,999 --> 00:00:18,999
    EMPTY.
    13
    00:00:18,999 --> 00:00:19,999
    SOMETIMES IT'S HARD TO SEE
    14
    WHAT WE'RE GOING TO
    15
    00:00:20,999 --> 00:00:21,999
    HAVE FOR
    16
    00:00:21,999 --> 00:00:22,999
    DINNER.
    17
    00:00:22,999 --> 00:00:23,999
    >> THE FAMILIES THAT ARE
    18
    00:00:23,999 --> 00:00:24,999
    FEELING THE PINCH.
    19
    00:00:24,999 --> 00:00:25,999
    >> WE JUST MISSED
    20
    00:00:25,999 --> 00:00:26,999
    A
    21
    00:00:26,999 --> 00:00:26,999
    REALLY
    22
    00:00:26,999 --> 00:00:27,999
    STABLE, TYPICAL
    23
    00:00:27,999 --> 00:00:29,999
    MIDDLE CLASS
    24
    00:00:29,999 --> 00:00:30,999
    EXISTENCE
  19. Former Member
    Dec 2007
    They look different to me. Maybe you converted them funny or something.
    http://ga.video.cdn.pbs.org/captions/local-usa/5667341e-c2f5-43c9-ae73-c5aba8853482/captions/143158_Encoded.srt
    Jul 2014
    Australia
    Thanks blimey for your quick reply. I follow strictly all the instructions given here, but when I found the dfxp file it gave me that big mess. Really dont know what happened, but thank you for your contribution. Unfortunately
    Ill never know how to get the correct file on a pbs movie. Maybe Im too dumb for it.
  21. Former Member
    Dec 2007
    Just add 1 to get srt instead of dfxp. For example, if you find;
    143157_Encoded.dfxp
    change to for srt;
    143158_Encoded.srt
    Keeping the beginning part of the url the same.
  22. I just joined this forum because I am desperately trying to download this PBS video:
    http://video.pbs.org/video/2365399272/
    I have limited knowledge in this but I managed to get as far as disabling flash in Firefox and downloading a copy using DownloadHelper. The problem is this is very low quality and the only way I can watch the HD video is with Shockwave enabled.
    I tried right clicking to get the URL but they are using JW Player so I am not seeing this option. (Just getting "about JW Player" option)
    If anyone could offer assistance for this particular case please advise. Thanks in advance.
  23. Originally Posted by cadrad View Post
    http://ga.video.cdn.pbs.org/videos/great-performances/56900ad5-c9f0-45da-a5d0-4b0b799270d7/165956/hd-mezzanine-16x9/bc3b3bc3_gper3817_mezz16x9-16x9-mp4-800k.mp4
  24. Hello guys,
    could you please help with finding the better quality for the following Frontline program:
    http://video.pbs.org/video/1099857730/
    What's the maximum quality?
  25. Hi ,
    What is said : Want better video quality? Sign in to access HD streaming!
    rtmp://sdwfchwqitj2v.cloudfront.net/cfx/st/mp4:videos/frontline/9243d3aa-b1f7-4a20-a1d9-a6c3ac4cb4d9/69808/hd-mezzanine-16x9/fline-2710-cove.mp4
    fline-2710-cove.mp4
    512 x 288
    http://ga.video.cdn.pbs.org/captions/frontline/9243d3aa-b1f7-4a20-a1d9-a6c3ac4cb4d9/captions/185410_Encoded.dfxp
    Cheers .
    JE SUIS CHARLIE !!!
  26. Hi,
    I am having trouble downloading a video because the server is returning a 403 forbidden error. Any ideas on how to get past this? The video I want is:
    http://video.pbs.org/video/2365432375/
    http://ga.video.cdn.pbs.org/videos/nature/27593648-1f9c-4b06-8139-efe5bd2ee65b/173090/...9-mp4-800k.mp4
    Thanks!
  27. Originally Posted by maestro88 View Post
    Hi,
    Thanks!
    hi
    ffmpeg -i http://ga.video.cdn.pbs.org/videos/nature/27593648-1f9c-4b06-8139-efe5bd2ee65b/173090/hd-mezzanine-16x9/41b66d81_p450996-001hdi-16x9-hls-800k.m3u8 -c copy  The-Last-Orangutan-Eden.ts
    or
    livestreamer "hls://http://ga.video.cdn.pbs.org/videos/nature/27593648-1f9c-4b06-8139-efe5bd2ee65b/173090/hd-mezzanine-16x9/41b66d81_p450996-001hdi-16x9-hls-64-800k.m3u8" best -o The-Last-Orangutan-Eden.ts
  28. Originally Posted by biezom View Post
    Hi,
    Thanks!
    hi
    or
    or http://ga.video.cdn.pbs.org/videos/nature/27593648-1f9c-4b06-8139-efe5bd2ee65b/173090/...4-baseline.mp4 but lower quality
  29. Originally Posted by biezom View Post
    hi
    or
    Works great, appreciate it!
  30. Hi,
    anyone knows why when using ffmpeg after 1 hour the recording stops?
