Results 1 to 9 of 9
  1. found this new site with some multimedia tools, haven't tried them yet
    AX Multimedia Components
    H264/AAC encoders, MP4 and Smooth Streaming muxers and more. Available as DirectShow filters or plain DLLs
    AVC and AAC encoders
    H264 (AVC) and AAC encoder components with top encoding quality and wide range of options to customize the output
    MP4 Multiplexer MP4
    Muxer component fully compliant with MP4 format specification (ISO/IEC 14496-12:2004)
    Smooth Streaming Multiplexer
    Smooth Streaming Muxer component allows you to author Microsoft® Smooth Streaming files (no Expression Encoder required)
    Seamless Switching File Writer
    Switching File Writer allows you to produce a series of multimedia files without interrupting the recording
    the site
    http://www.ax-comp.com/
  2. DECEASED
    Jun 2009
    Heaven
    r u a zpammer
    Feb 2013
    Toronto, Canada
    What's the name of the site? I didn't quite get it.
    Is he gone?
  4. guys
    just try them and post the results
    don't have time to test them now
  5. DECEASED
    Jun 2009
    Heaven
    Step#2 is not OK
    1) those filters are proprietary kräpp, not compatible with the default File Writer, or with the AVI Muxer
    2) H264 compressor: overall quality is terrible, ratecontrol seems broken
    3) half-ässed filters have been successfully un-registered
  6. El Heggunte (aka guinea pig) . Spidey sense go tingly when a solo post counter wants you to download software for testing hmmmmm
  7. Yes, El has more nerve than I have.
    Inside Every Older Person Is A Younger Person Wondering What The Hell Happened.
    Apr 2014
    Hi guys,
    I'm one of the developers of AX Multimedia Components. I appreciate Compuitguy posting the information about our software here.
    El Heggunte, thanks for testing the components.
    There's a reason behind it, and that's the inability of default File Writer to produce a series of recorded files without stopping the recording. That's one of the "killer" features of our components. Thus we have our own muxer and file writer that provide clean "cutting" of files. It's really needed for those who are recording for long periods of time or 24/7
    I'm surprised to hear this, may I ask what resolution and bitrate did you use? The encoder is using x264 library, which has the best quality among the competition. Please check the filter settings screenshot:
    http://ax-comp.com/img/scrn/avc_encoder.png
    There are a number of settings to tweak, so maybe something was wrong with them in your setup.
    Thank you for your feedback
    PS: the components are free for personal use
