    Apr 2014
    Estonia
    I have a dvdrip with makemkv which I want to reencode (mpeg2 to h264). The problem is that there are many of those files and only some have multiple angles in them. What software would be easiest/quickest? My primary tool is a macbook, I also have a Ubuntu and Win7 box.
    Cheers,
    Sven
    You could try handbrake and see how it handles it. But I guess it will tricky with a multiple angle mkv....
    Apr 2014
    Estonia
    Handbrake takes only the first video track to the encode :/
    Easiest would be to use the dvd source directly instead of the mkv.
    Or maybe try mkvmergegui to just extract the tracks you want.
    Apr 2014
    Estonia
    Yes, It looks like I need to extract the tracks and process them separately. Then even Handbrake can help me.
    I wish there was a Xin1generator + encoder thingy for DVDs too.
