    Feb 2014
    Country
    I Would like to know if there is any software i can use that download DRM files while the media is playing on the webpage... to remove the DRM Protection
    I tried with Flash Stream Hunter and it didn't work, the file still had the DRM, then i Tried with WM Converter, didn't work either. is there any other software i can use that will actually remove this thing and keep the original file size?
    I do have have the key (login and password), so i can play the video on a web browser, but I want to download it without the DRM protection so i can watch it whenever I want, I thought that Flash Stream Hunter could work, but it didn't, it didn't removed the DRM protection
    if there's no way to make it happen with a stream catcher, how can i burn the image of the file into a DVD and import it again to my PC? If i do this, is it going to remove the DRM? Is the file going to be just like the original? same size? same quality
    Can you guys help me with this? please?
    Nope.
    You could try screen capture program.
