Results 1 to 10 of 10
  1. How did this guy pull this off? I am unable to reproduce the result with Sound Forge.
  2. Member Cornucopia's Avatar
    It's just a decent quality reverb (sounds to me more like a plate than hall), done subtlely. You should be able to do it with SF. Might try a few other 3rd party Dx or VST plugins (Sony's stock plugin doesn't give you a lot of options).
  3. This is the best I can do with Ozone Reverb. Can anyone do better? Why does mine sound so metallic? How do I get that deep echo effect?
    Apr 2014
    Edmonton
    There are a few differences. In the reverb you are trying to achieve there is a long delay before the main reverb effect starts. The delay is around 600-700ms. Their reverb sounds like a hall emulation. The reverb either uses a LPF or naturally rolls off high end. I'd use a low pass filter at 6-12db per octave at about 5khz if your reverb is too bright.
    Your reverb sounds like a plate with that washy decay. Yours also sounds mono and the original is quite stereo.
    If I were setting this up and my reverbs weren't cutting it for me here is what I would try next.
    Use an aux send on your audio track and put a delay on the aux. Set the delay to about 600-700ms and then fine tune the delay time to get you the delay. Set the feedback so you get one loud delay and then one or two quiet delays. Next put a stereo reverb on the delay track. Set the early reflection time to zero on the reverb. Add the LPF to the aux track either before or after the reverb and you are in business. This should get you closer so you can finish this up.
  5. Member Cornucopia's Avatar
    I don't have time right now to even test this out for you, so you'll have to go with some other suggestions (Paul999's sounds good).
    What other thing you can do is this:
    If, you have the ORIGINAL and you have the PROCESSED, you can DECONVOLVE the processed with the original to derive the convolution impulse response (which is basically the "thing that makes it sound like that"). You can take that and CONVOLVE another soundfile with it.
  6. Originally Posted by Paul999 View Post
    In Ozone Reverb I can't set the delay longer than 100ms so I will need another app.
    I can't figure out whether its a plate or hall, plate is too metallic and hall is WAY too echoey especially on lower shelf.
    Yes, cornucopia advised to use plate and that did work out better than hall with the settings I've tried. I'm not sure if the original is really stereo. On the game the music is predominantly mono but I'll never know the exact source the author used and then reverbed, he could've remastered it into stereo.
    Aux send? What program do you recommend?
    @Cornucopia
    I don't have the exact original. The output of the .gbs file has a louder upper shelf but I can fix this manually to match the equalizer of the reverbed. Should I still try the deconvolution? What program/plugin do you recommend? I haven't found too many deconvolvers.
  7. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    "Auxiliary Send" with a delay causes an offset in the convolve, and there's your reverb. You need a real DAW to do this. It's called "Side Chaining" in Ableton Live.
    Any decent DAW has tons of reverb tools. Somebody mentioned one the other day that was around $50, and looked pretty good, but I can't remember it. I'll look for it.
  8. Great, I have Ableton Live but I used it only twice in a year and for only one purpose so I'm not familiar with it. You'd have to hand-hold me thru the process.
    Cornucopia's deconvolver sounds better though. Is Ableton capable of that?
  9. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Well, Scott is saying to subtract the reverb out and I don't know how to do that.
