  1. Hey Guys,
    I am not a TOTAL noob .. but compared to the guys in this forum I am.
    I have been slowly converting my blu ray library to files on my NAS(synology). I want streamable 1080p files of high quality. I have been using PAVTUBE for this until now.
    QUESTION : is there a recipe for high quality rips anywhere ? I mean literal recipe ... such as
    1. Do this with this program
    2. then do this
    3. your done =)
    I just have a feeling the quality from pavtube is not optimal.
    I just downloaded ANyDVD HD for the trial.
  2. Member steptoe's Avatar
    AnyDVD HD or DVDFab Ripper to strip the encryption from the discs (I personally prefer AnyDVD HD)
    Use MakeMKV to convert the rip to a single MKV file (100% quality, zero loss, but huge file size)
    Or, run through VidCoder as a GUI for HandBrake (but a lot easier to use) to reduce the filesize but manage to keep good quality. VidCoder is pretty much ready to run with defaults but can be tweaked all day to squeeze as much quality as you can out of the source. You can also get VidCoder to do all the hard work just by setting a maximum filesize
    MediaCoder can also be used, and also use the GPU in some modes to speed things up. I also use VSO Video Converter as that fully supports GPU encoding, and some tweaks if you create your own custom projects
    For simplicity, VidCoder is better than most at doing what it has to do without banging your head on the table trying to get the settings right
    The only real cost is the disc encryption removal software. Both AnyDVD HD and DVDFab Ripper are 'technically' free but have various ways to convince you to buy it. AnyDVD has a constant nag everytime you want to use it, DVDFab only strips 'some' encryption methods. Normally it won't touch the ones that the majority of blu-rays use, so convincing you to buy it as its not much good for new discs
  3. I assume I can strip the protection using my copy of Pavtube instead of AnyDVD. I just use the entire disk option ? I donwloaded Handbrake .. it crashes when I run it.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Who told you that?
  5. Originally Posted by hech54 View Post
    Who told you that?
    Ha ... I was just thinking that since I could rip Lossless copies with pavtube that I would be able to then compress with something else. I want to create teh smallest possible file with awesome video quality. All my HD .mp4s end up looking 'ok' at around 11 GIG.
