Results 1 to 9 of 9
  1. HI every one .
    This is how I convert videoes to flv but the quality is decreasing very much .
    passthru("$ffmpegpath -i uploads/$video_name -ar 22050 -ab 32k -f flv -s 480x800 uploads/vid.flv");
    How can I convert videos without any decrease of quality ?
  2. If the source video uses compatible compression with FLV container (e.g. h.264, h.263, VP6), just stream copy the video . No quality loss
    -c:v copy
    Otherwise some quality loss is unavoidable in FLV container (it doesn't support lossless codecs - except lossless x264, which isn't supported by flash which I assume you are using this for - and they are huge in filesize anyways)
    You can minimze the loss by re-encoding using a better encoder like libx264
    -c:v libx264
    And/or by increasing the bitrate, or lowering the quantizer or crf values
    Nov 2002
    Here are a few batch files to convert FLV files. You'll need to place a copy of ffmpeg.exe and cmd.exe in the folder you want to convert. Copy each command in Notepad and save as .bat
    bat files
    FLV-2-MP4.bat
    for %%a in ("*.flv") do ffmpeg -i %%a -vcodec copy -acodec copy %%~na.mp4
    Nelly-FLV-2-AC3-MKV.bat
    for %%a in ("*.flv") do ffmpeg -i %%a -vcodec copy -acodec ac3 -ac 2 -ar 48000 -ab 128k %%~na.mkv
    Nelly-FLV-2-264-MKV.bat
    for %%a in ("*.flv") do ffmpeg -i %%a -vcodec h264 -vf "scale=512:-1" -acodec libmp3lame -qscale 0 %%~na.mkv
    Nelly-FLV-2-MP3.bat
    for %%a in ("*.flv") do ffmpeg -i %%a -vcodec vn -acodec libmp3lame -qscale 0 %%~na.mp3
    Nelly-FLV-2-X264-MKV.bat
    for %%a in ("*.flv") do ffmpeg -i %%a -c:v libx264 -preset superfast -crf 24 -acodec libmp3lame %%~na.mkv
    VP6-2-H264-MKV.bat
    for %%a in ("*.flv") do ffmpeg -i %%a -c:v libx264 -preset superfast -crf 24 -acodec copy %%~na.mkv
    cmd.exe will ignore files with spaces in filename so I use this replace-spaces-with-dashes.vbs file to remove spaces.
    vbs file - replace-spaces-with-dashes.vbs ( can easily change the pattern to "_" )
    dim objFileSys, file, folderName, folderObj, fileColl, objRegEx, newFile
    set objFileSys = CreateObject("Scripting.FileSystemObject")
    folderName = InputBox("Enter the full path where the files are located.", "Full path is required")
    set folderObj = objFileSys.GetFolder(folderName)
    set fileColl = folderObj.Files
    set objRegEx = new RegExp
    objRegEx.Pattern = " " ' the pattern is one space
    objRegEx.Global = true
    for each objFile in fileColl
    newFile = objRegEx.Replace(objFile.Name, "-") ' each pattern gets replaced with one dash
    objFileSys.MoveFile objFile, folderName & "\" & newFile
    next
    EDIT: It's best to separate each type of FLV into it's own folder.
    Example: VP6, AVC/aac, Sorenson (nellymoser)
  4. all filenames should be in quotation and then there could be spaces in a file name or along the way in its path, for example: "%%~na.mp4" or even "%%a" if it is placed after DO
  5. HI
    thanks for the replies .
    I told my server to upgrade to latest version of ffmpeg and they told me they did and I have the latest version that is 2.2.1 .
    I test several codes to convert a video to x264 , here is the one ;
    passthru("$ffmpegpath -i aatest/a.AVI -c:v libx264 -c:a libfaac -preset veryslow -qp 0 aatest/output.mp4 2>&1");
    now ,when I run the page, it shows me this error :
    FFmpeg version 0.6.5, Copyright (c) 2000-2010 the FFmpeg developers built on Jan 29 2012 17:52:15 with gcc 4.4.5 20110214 (Red Hat 4.4.5-6) configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lavf --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enable-version3 --enable-x11grab libavutil 50.15. 1 / 50.15. 1 libavcodec 52.72. 2 / 52.72. 2 libavformat 52.64. 2 / 52.64. 2 libavdevice 52. 2. 0 / 52. 2. 0 libavfilter 1.19. 0 / 1.19. 0 libswscale 0.11. 0 / 0.11. 0 libpostproc 51. 2. 0 / 51. 2. 0 [mpeg4 @ 0x1111960]Invalid and inefficient vfw-avi packed B frames detected [mpeg4 @ 0x1111960]frame skip 8 Input #0, avi, from 'aatest/a.AVI': Duration: 00:02:04.04, start: 0.000000, bitrate: 885 kb/s Stream #0.0: Video: mpeg4, yuv420p, 480x360 [PAR 4:3 DAR 16:9], 25 tbr, 25 tbn, 25 tbc Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 128 kb/s Unrecognized option 'c:v'
    the last line says "Unrecognized option 'c:v'"
    What should I do ?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    You need a newer version. That is not version 2.2.1.
    Nov 2002
    Can you show the complete command to convert the whole folder from x264/aac flv to x264/aac mp4? Not sure what you mean since ("*.flv") is already in quotes and it's cmd.exe's problem of not being able to read the file with spaces to open it.
  8. for %%a in ("*.flv") do ffmpeg -i "%%a" -vcodec copy -acodec copy "%%~na.mp4"
    but I like those drag and drop batch files, you can build up on this, it creates functions basically, for example this one, that zip below, where typing this line (into cmd or another batch script):
    "flv to mp4.BAT" "your flv.flv"
    makes "your flv.mp4"
    And Windows 7 has that cool feature, that you just launch Cmd.exe, drop "flv to mp4.BAT" file in there from windows explorer, press "space bar" and drop "your flv.flv" file in there, it creates command line for you, you just run it pressing "enter" and done
    but this is off topic, not really php useful, that windows OS ... anyway, worth mentioning that dropping feature into cmd window, saves a lot
    Nov 2002
    Thanks! Ya learn something every day. I just started using Windows 7 so I'll have to try those tricks also.
