    Apr 2014
    Philippines
    Guys, well im kinda new on these things...
    Hence I post here on the Newbie section
    I got a problem with a DVD File saved on my PC with the Folder AUDIO_TS and VIDEO_TS
    now the problem is that I want to remove the other language subs and I just want to use the English one, but there is somehow I noticed when I choose on the Eng sub theres no sub showing (by the way im using the VLC to test it)
    and somehow in the middle of the playtime there are another set of subtitles like Track 5 [with no Label] and Track 6..
    and in the Track 5 its the sub that I want to use.
    Please help me with this one.
    Can anyone help me edit this .IFOs
    Really appreciate if anyone helps.
    Attached here is the screenshot and the IFOs.
    Here are the .IFO.rar
    If you can't see any subs there might not be any subs...try open the dvd with dvdsubedit and see if you can see any english subtitles.
  3. Banned
    Freedonia
    You would have to go to the original DVD disc to be absolutely sure as it is possible to rip DVDs and not rip certain subtitles. It's also possible to define a subtitle field while authoring a DVD and have nothing in it. It gets done all the time. Why does it get done? I have no idea.
    canada
    Do any of the other subs show up when you select them?
