    Dec 2003
    I've purchased a car stereo that lists the following dimensions:
    6.95 in diagonal (156.6 mm x 81.6 mm)
    800x480, 16:9 aspect ratio
    If the pixels were square, that would be 15:9 but the physical dimensions are definitely 16:9.
    If I have a video encoded at 720p or 1080p and I want to convert it to use the entire 800x480 display and the non-square (?) pixels, how can I do this with FFmpeg? (or anything else)
  2. DECEASED
    Jun 2009
    Heaven
    AR = 16:9 => 852x480 or 800x448
  3. Member Cornucopia's Avatar
    156.6 / 81.6 is 1.9191, so definitely not 16:9 (aka 1.78:1).
    If you truly trust what it says, you should size as if it was 852x480, but then actually make it the target size.
    Dec 2003
    If I size the output from 1280x720 to 800x448, won't I be losing 32 pixels on my screen? Shouldn't I be able to fit it 100% since they are both 16:9 aspect ratios?
    I'm sorry but can you explain that a bit more? What would the command-line parameters be for FFmpeg? (does the source resolution or aspect ratio matter?)
  5. DECEASED
    Jun 2009
    Heaven
    Obviously, 800x480 IS NOT 16:9, even if the user's manual states otherwise.
    800x480 is 50:30, or 1.666......
