Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 13 of 13
  1. I have a gopro video which is rotated upside down. I rotated with avisynth, to make easier to cut. Of course I can re-convert than bring into Premiere, but for later projects, where quality will be matter, would be nice to frame serving somehow to Premiere Pro CC!
    I created a fake AVI file with ffdshow's makeAVIS. I want to bring in Premiere Pro CC this fake AVI, but simply not work. PP says corrupted audio and video. However, x86 video players (mpc-hc, wmp) will play this fake avi files without problem.
    It will open up endless possibilities if somehow possible to bring fake AVI files from avisynth into Premire Pro CC or Lightroom or Photoshop! DNG grading frame by frame in image groups in Lightroom, than bring this sequence by fake AVI from avs script into Premiere Pro CC! In theory this is nice, but some reason Premiere doesn't like the fake avi file...
    Is it possible?
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    you should be able to do it with AVFS.
  3. Member turk690's Avatar
    Jul 2003
    ON, Canada
    Though frameserving out of Premiere to an *.avs file is probably what mostly happens here, one can import and play these *.avs files in Premiere, too, by, for starters, installing Premiere avisynth plugin and importer.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  4. Most of these Premiere Pro import export AVS plugins are outdated. Last supported Premiere version was CS5.
    I will try the AVFS way.
  5. Member racer-x's Avatar
    Mar 2003
    AVFS should work. It worked on everything I tried, even in HitFilm. Depending on your source and the program you are using, you may need to add ConvertToRGB(24) at the end of your script for best compatibility.
  6. Is there any reason you can't make a lossless AVI (Lagarith, UT Video Codec, whatever) for opening in Premiere?
  7. Member turk690's Avatar
    Jul 2003
    ON, Canada
    Originally Posted by Lanti View Post
    Most of these Premiere Pro import export AVS plugins are outdated. Last supported Premiere version was CS5....
    I'm still using Premiere Pro CS5.0.3. But thanks to you I'll try AVFS.
  8. Can't you just open your GoPro footage in Premiere and flip it there? Did I miss something?
  9. Originally Posted by smrpix View Post
    Is it possible to flip it on the Source Monitor? Because if it is, than I don't need frameserving. Hard to choose sequences, when you watching the source upside down...
  10. Originally Posted by manono View Post
    Yes, free space.
  11. ..double post
  12. Originally Posted by Lanti View Post
    Just use your corrected sequence as a source. Drag it into the source monitor.
  13. An alternative to MakeAVIS.
    I used to use it quite a lot (although not with Premiere).
    Once it's installed you can right click on a script and select "wrap into AVI". I'd often extract the audio from the source, convert it to an AVI friendly format if need be, open the AVI created by avstoavi with VirtualDubMod, add the extracted audio, then save it as a new AVI using direct steam copy for the video.
