Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Closed Thread
Results 1 to 13 of 13
  1. I can't get any media player on my computer to open this MKV file i downloaded. I know there is nothing wrong with the file because i downloaded it from a public site and noone else has reported any kind of problems.
    The file finished on Jdownloader and upon finished had another file next to it that ended in mkv.decrypted. This is the file that has the video files information, the video file gives me no such info.
    Is this a codec issue? Do these files need to be merged? Any help would be appreciated.
    Here are the files details:
    General
    Unique ID : 224582290669426812373645586038455765547 (0xA8F4F9D1D35295168148C526984F8A2B)
    Complete name : C:\Program Files\JDownloader\downloads\Cinderella.mkv.decrypt ed
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 516 MiB
    Duration : 1h 14mn
    Overall bit rate : 969 Kbps
    Movie name : CINDERELLA_1995.Title1.DVDRip
    Encoded date : UTC 2013-07-26 04:27:59
    Writing application : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
    Writing library : libebml v1.3.0 +
    Bit rate : 204 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 fps
    Original frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.025
    Stream size : 108 MiB (21%)
    Default : Yes
    Forced : No
    Color primaries : SMPTE 170M
    Transfer characteristics : SMPTE 170M
    Matrix coefficients : SMPTE 170M
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Format profile : MA / Core
    Codec ID : A_DTS
    Duration : 1h 14mn
    Bit rate mode : Variable
    Bit rate : 618 Kbps / 384 Kbps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossless / Lossy
    Delay relative to video : 9ms
    Title : Original Mono DTS
    Language : English
    Default : No
    Forced : No
    Audio #2
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 1h 14mn
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Bit depth : 16 bits
    Delay relative to video : 31ms
    Stream size : 68.2 MiB (13%)
    Title : Original Mono AC3
    Language : English
    Default : Yes
    Forced : No
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    You didn't say if you tried to use VLC player for playback or MediaInfo to see what specifications the file has. If neither work, I would assume the file is corrupted and you should try another download. And your file details doesn't seem to list the format of the video.
    And welcome to our forums.
  3. Originally Posted by redwudz View Post
    I copy and pasted everything under Media info, it's definitely an MKV. I used Everything from VLC to MPC and nothing worked. I got no error messages at all, the file just never begins playing.
    edit* Sorry i left off the top portion of the Media Info. I just added it!
  4. Originally Posted by jade88 View Post
    The mediainfo report displays no codec. The video bitrate is spectacularly low, so there may be no video.
  5. Originally Posted by smrpix View Post
    That mediainfo was taken from a file called Cinderella.mkv.decrypted that randomly appeared when my download finished.
    The Actual 4.45 Gig video file has this under mediainfo
    Cinderella.mkv
    General
    File size : 4.46 GiB
    and that is it!!!
  6. DECEASED
    Jun 2009
    Heaven
    General
    and that is it!!!
    Either that's NOT a Matroska file, or it was corrupted during the file transfer process.
    Mar 2011
    Nova Scotia, Canada
    ... I copy and pasted everything under Media info, it's definitely an MKV...
    Yes, it's definitely an mkv. But 'mkv' is just a container.
    As srmpix mentioned, there is no video codec ID listed in the video part of the mediainfo output.
    If you don't know the difference, don't get pissy about it.
    There's something fishy about that file.
  8. Here is the links i used
    Everybody else on the site i use has downloaded this just fine. I guess something happened when Jdownloader extracted the files?
  9. I went under Mediainfo when trying to play the file on VLC and the codecs i see listed are
    MPEG- 1/2 video (mpgv)
    MPEG Audio layer 1/2/3 (mpga)
  10. This can't be legal.
  11. Originally Posted by smrpix View Post
    Legal?
  12. This material appears to violate copyright restrictions as well as any reasonable definition of fair use. Discussing this is not allowed on this forum.
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Buy it instead. Don't link to warez.
