  1. Hi, im trying to stabilize this anime, i used stab on avisynth
    Stab(dxmax = 1, dymax = 1, range = 1, mirror = 15)
    But the result stills very bad, please could someone help me.. i uploaded a sample
    https://mega.co.nz/#!bV8WkKgB!QXKVhZ3d1jj5dhkQcY9FZxJbl79xgi2uQdhCdvZ2llo
    Thanks!
  2. Member DB83's Avatar
    Jul 2007
    I have not downloaded your sample as I can not really help you.
    However, it would be more useful if you posted your full script and not just one line.
    Also, many will not go near file-hosts for possible security issues and you could upload this sample, which is less than 100 meg, direct to the forum. Another advantage will be that the sample will 'live' longer and people coming to this topic in months, or even years, should still be able to make use of it.
  3. Ok i will upload it, its a 30mb sample ..
    my script its simple, the only thing i want to do it is stabilize it
    mpeg2source("original.d2v")
    tfm()
    decimate()
    Stab(dxmax = 4, dymax = 4, range = 4, mirror = 15)
    Lanczosresize(720,540)
  4. Member DB83's Avatar
    Jul 2007
    Well I did d/l the original.
    What pray tell me is wrong with that ?
    Your issue may well be related to altering the vertical height of a mpeg source.
  5. Altering what? i resize it at the end..,
  6. Member DB83's Avatar
    Jul 2007
    Might I then suggest you also upload the same sample as processed by your script.
  7. Stab will only help with short period X,Y translations, ie, film bounce. It won't help with longer period wobbles, rotations, rolling shutter distortions, etc.
