Results 1 to 14 of 14
    Jan 2014
    Slovakia
    Hi!
    I found on this forum new program - DScaler which works perfectly... but
    I own 3 USB grabbers and 2 of them have 2 inputs - Composite and S-Video, one of them has 4 Composite inputs.
    I tried to select manually Composite or S-Video but DScaler changes no source, and always displays the same...
    How to do it?
    Thank you for everything!
    Miro
  2. Member DB83's Avatar
    Jul 2007
    I do not quite understand what you are saying.
    To get a picture from the s-video connection on the usb device you must have a s-video cable plugged in and the output device MUST output s-video. Many VHS machines will not.
    But a usb device with 4 composite inputs ???????
    Aug 2006
    They exist. Their intended use is monitoring closed-circuit cameras. http://www.amazon.com/HDE-EasyCap-Model-002-Channel/dp/B001M547EM
    Jan 2014
    Slovakia
    It looks like if is one signal detected then is impossible to select other from one device...
    First time I had for testing DScaler connected only S-Video to one device and it was correctly displayed, after this test I connected also composite video to the same device and it looks first was found composite and it's now impossible to select S-Video - but S-Video is connected too...
    How to select between composite and S-Video ?
    Yes, it's EasyCAP002 - but works not with my Win8
    Miro
  5. I've never used descaler or that particular capture device, but generally you go to the properties sheet for the capture filter or crossbar filter and select which input you want.
    Jan 2014
    Slovakia
    I tried crossbar - but the same - not possible to chage input
  7. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    AmarecTV works. You can configure individual source.
    For Windows 8, get Windows 7 drivers and install by .inf.
    Aug 2006
    Miro
    I have not used DScaler for a long time, but it is probably designed to be used with one video connection at a time and one device at a time, not several connections at once or several devices at once. If you need to switch between multiple devices and multiple video connections use something other than DScaler. You can try AmarecTV as suggested.
    Jan 2014
    Slovakia
    I need at once use only one device - if is available two...
    My experience with DScaler was great in case of deinterlacing - it displays correctly unbelievable modes...
    I'll try AmaRecTV, please give me bit of time to try use these modes, then I'll reply...
    Miro
  10. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Miro
    AmarecTV has one better deinterlaced filter at moment. You can deinterlaced and set captured file to give on/off feature (25/50 or 30/60).
    Ah make individual set to deinterlaced too.
    Jan 2014
    Slovakia
    Thank you veeeeeery much!
    The experience with AmaRecTV is better than DScaler... all works correctly and interlaced options are perfect!
    I have few Qs as last:
    My TV cart MSI @nywhere A/D has also composite and S-Video inputs and both reports error: return:HRESULT=80004005 (FAILED) Unknown Error
    ... where is any problem?
    And: AmaRecTV allows to use 12 sources - is possible to display at least 2 together at once?
    My general problem:
    SMI EasyCAP002 USB 2.0 DVR 4CH Dongle:
    - at connection to PC appears "USB device was not recognized. Please unplug and plug-in again"
    - in Device Manager it shows only "Unknown Device" with error message "Windows stopped device 'cause device reported problem (Code 43)"
    - if I install driver by wizard, no changes, if I try it manually reports "Digitally not signed" and breaks installation or I tried to install driver in Vista SP2 compatibility mode, installation reports succesfull but device is not known...
    Can you help me to these last Qs?
  12. It's ok to deinterlace while previewing a video but I would never deinterlace while capturing. You wan't to have an unmolested capture as your starting point. If you have a need to deinterlace later do so with QTGMC in AviSynth.
  13. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    My general problem:
    Try this driver : http://www.sabrent.com/drivers/USB-AVCPTSetup_For_Win7.zip
    Its a old thread in Videohelp: http://forum.videohelp.com/threads/329555-EasyCap-Video-Adapter-Driver-for-Windows-7-64-bit
    Jan 2014
    Slovakia
    Driver helped not... I'm desperate - this device was working few minutes, then not, then again working and ~2 months not working...
    I look at that topic later, here's few minutes before midnight..
    Miro
