  1. Hello,
    I recorded this TS file (mediainfo below), and as usual I wanted to repair it before encoding it to mp4 with Megui.
    Problem when I try to repair TS file, Videoredo says error just before the end, TSdoctor removes pretty all leaving 6minutes "correct" on 3 hours video.
    When I try to demux file with HDstreamextracor I get "ouch" Megui popups and:
    ion] [24/03/2014 00:39:45] Process started
    --[Warning] [24/03/2014 00:39:45] Standard output stream
    ---[Information] [24/03/2014 00:40:02] TS, 1 video track, 1 audio track, 50i
    ---[Information] [24/03/2014 00:40:02] 1: h264/AVC, 576i50 (20:11)
    ---[Information] [24/03/2014 00:40:02] 2: MP2, French, 2.0 channels, 128kbps, 48kHz, -11528ms
    ---[Information] [24/03/2014 00:40:02] v01 Extracting video track number 1...
    ---[Information] [24/03/2014 00:40:02] v01 0:00:00 Skipping dirty PES bytes...
    ---[Information] [24/03/2014 00:40:02] a02 Extracting audio track number 2...
    ---[Information] [24/03/2014 00:40:02] a02 0:00:00 Skipping dirty PES bytes...
    ---[Information] [24/03/2014 00:40:02] v01 Muxing video to Matroska...
    ---[Information] [24/03/2014 00:40:02] a02 Applying MPx delay...
    ---[Information] [24/03/2014 00:40:02] a02 A remaining delay of -8ms could not be fixed.
    ---[Information] [24/03/2014 00:40:02] a02 0:00:11 Skipping dirty PES bytes...
    ---[Information] [24/03/2014 00:40:02] v01 0:00:11 Skipping dirty PES bytes...
    ---[Warning] [24/03/2014 00:40:03] v01 0:00:11 Skipping dirty PES bytes...
    ---[Warning] [24/03/2014 00:40:08] v01 0:00:11 Skipping dirty PES bytes...
    --[Information] [24/03/2014 00:39:45] Standard error stream
    And then it sleeps at 13 percent...
    Général
    Nom complet : C:\Users\Masmas\Desktop\REC_0001\velo.TS
    Format : MPEG-TS
    Taille du fichier : 3,50 Gio
    Durée : 2h 36mn
    Type de débit global : Variable
    Débit global moyen : 3 192 Kbps
    Vidéo
    ID de menu : 34 (0x22)
    Format : AVC
    Profil du format : High@L3.0
    Paramètres du format, CABAC : Oui
    Paramètres du format, RefFrames : 4 images
    Identifiant du codec : 27
    Durée : 2h 36mn
    Débit : 2 905 Kbps
    Largeur : 720 pixels
    Hauteur : 576 pixels
    Format à l'écran : 16/9
    Images par seconde : 25,000 Im/s
    Norme : PAL
    Espace de couleurs : YUV
    Sous-échantillonnage de la chrominance : 4:2:0
    Profondeur des couleurs : 8 bits
    Type de balayage : MBAFF
    Ordre de balayage : Ligne du haut d'abord
    Bits/(Pixel*Image) : 0.280
    Taille du flux : 3,18 Gio (91%)
    Encryption : Seca Mediaguard 1/2
    Coordonnées de chromaticité : BT.601 PAL
    Caractéristiques du transfert : BT.470 System B, BT.470 System G
    Coefficients de la matrice : BT.601
    Audio
    Format : MPEG Audio
    Version du format : Version 1
    Profil du format : Layer 2
    Paramètres du format, Mode : Joint stereo
    Identifiant du codec : 4
    Durée : 2h 36mn
    Type de débit : Constant
    Débit : 128 Kbps
    Canaux : 2 canaux
    Echantillonnage : 48,0 KHz
    Mode de compression : Avec perte
    Délai par rapport Vidéo : -488ms
    Taille du flux : 144 Mio (4%)
    Langue : Français
    Menu
    Durée : 2h 36mn
    Liste : 178 (0xB2) (AVC) / 154 (0x9A) (MPEG Audio, Français) / 218 (0xDA) () / 281 (0x119) () / 1249 (0x4E1) () / 206 (0xCE) () / 343 (0x157) () / 347 (0x15B) ()
    Langue : / Français
    UTC 2014-03-23 11:25:00 : fr:Football / fr:Football. Championnat d'Italie. 29e journée. Parme / Gênes. Football / football/soccer / / 02:00:00 / Running
    UTC 2014-03-23 13:25:00 : fr:Cyclisme / fr:Cyclisme. Milan - San Remo 2014. 299 km. En Italie. Cyclisme / reserved for future use / / 03:05:00 / Running
    UTC 2014-03-23 16:30:00 : fr:Football / fr:Football. Championnat d'Italie. 29e journée. Torino / Livourne. Football / football/soccer / / 00:55:00 / Not running
    How can I repair it correctly please?
  2. Member DB83's Avatar
    Jul 2007
    When you say 'as usual' are you saying that you ALWAYS have to 'repair' the recording ?
    Have you successfully 'repaired' from this same source before ?
    I just wonder if the programs are coughing at the digital encryption which means you can record but only playback through the playback device.
  3. DB83,
    Actually yes I have already repaired TS files from this source, never had problems.
  4. Member DB83's Avatar
    Jul 2007
    Can you play the .ts file ?
    Clutching at straws here. It is still possible that the broadcaster has changed the encryption.
    Can you stream copy a short sample - just a few minutes is enough - and upload it here ?
    The word 'repair' still bothers me since why should the original stream require repairing ?
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Try ProjectX in Demux mode (the only mode that repairs transmission errors)
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
