Results 1 to 11 of 11
    Jan 2013
    Under the Boardwalk, AC, NJ
    I have a friend who uses an older handi-cam, palmcorder (whatever it is called) and records the video on DVD mini-disc. She would like to compile all of the mini discs into one regular DVD and send to relatives. The recorded medium on the disc is video.ts.
    My question what is the better/best authoring DVD software for her to compile/edit/create a single regular size DVD for her collection of these mini DVD's?
    thanks
    Jan 2013
    I read your tips and tricks guide for doing this and I have DVDFab but looking to pick the brains here for a possibly better or easier program?
    thanks again
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    First step would be to create a new folder on the computer.
    Inside that folder create a new folder for each mini-dvd.
    All you need to do is Copy & Paste the VIDEO_TS folder from each mini-dvd since homemade DVDs are not copy protected(no need for DVDFab).
  4. I like to use TMPGenc DVD Author to do that. It's not free, but it works very well, doesn't re-encode anything, has basic editing and pretty advanced menu creation abilities (though it's not very obvious). The latest version is called TMPGEnc Authoring Works, it's a bit pricey and for the same money you can get Sony Movie Studio or Premiere Element. Both are more capable editors, but I'm not sure about the re-encoding bit. Actually all your friend wants to do is author a DVD from several other DVD's, so the ability to edit might not be that important. In this case DVDAuthorgui would be fine, it's free and here's a guide for it. These are the most popular programs, there are other options.
    Jan 2013
    My friend added a new twist, she wants to incorporate some pictures as well into the final product! So the software I'm looking for (she needs) will need to be able to assimilate DVD video.ts and pictures, (mpg, GIF, etc.) for the final DVD creation!
  6. I'm a Super Moderator johns0's Avatar
    canada
    TMPGEnc Authoring Works will do what you want as nic2k4 has already posted.It's the easiest but you gotta buy it,you can use the trial version first to see if it fits the bill.
  7. Originally Posted by pclaptop View Post
    If we're talking about a slideshow she can use DVD slideshow GUI to generate DVD files that she can add along with the camcorder footage. The program is also free, but as with most freeware the level of complexity and hoop jumping increases every time you try to do more than basic things. If this is not a one time job TMPGEnc Authoring Works is worth the expense.
    Jan 2013
    thanks gentlemen
    Jan 2013
    one question nic2k4 the DVD slideshow GUI will that proggie incorporate video/ts clips along with the pics?
  10. No, all it does is turn a series of pictures into a slideshow and output ready to burn DVD files. She would then add that slideshow to the rest of her camcorder footage in DVDauthorGUI.
    Jan 2013
    thanks again for your replies
