Results 1 to 18 of 18
    Mar 2014
    Hello, I own this product http://tinyurl.com/o87mghu
    and I'm trying to set it up on my PC using a Sewell powered HDMI splitter and AmarecTV.
    When I have all the cable properly plugged in, I got audio on the stock Aver Mediacenter program with no video from which I assume is the HDCP, but doesnt necessarily make sense due to the HDMI splitter.
    However when I go to the AmarecTV program, I get a flickering image of what is supposed to be displayed: http://oi60.tinypic.com/2zicxfs.jpg
    I know the device works properly because I used to run it fine with my Xbox 360 but since I've started using the PS3 it hasnt been functioning.
    Often time AmarecTV gives me the display message: Device is not functioning. But after a couple times closing the program it begins to read the device but still gives me the broken image.
    Any help is appreciated.
  2. Have you changed your hardware setup since it was working with the Xbox?
    Possibly see whether it's still working with the Xbox or not.
  3. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    My setup for PS3 using AverTV HD C027
    Deinterlaced mode:
    Mar 2014
    Nope, everything's still the same. Cant image the issue.
    Mar 2014
    Deinterlaced mode:
    That's the exact same model im using, what version Amarec are you using?
  6. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Link: http://download.forest.impress.co.jp/pub/library/a/amarectvammk/10925/amarectv300c.zip
    Mar 2014
    I'm repeatedly getting this error message and it's clearly connected. Any help for this?
  8. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Hi NickDiGi,
    Try it:
    1 - Uninstall any codec pack on your system, use ccleaner and reboot.
    2 - Update videocard drivers
    3 - Install latest K-ile Codec Pack using LAV default for all.
    4 - Reset your PS3 video settings: PS3 connected on C027, press and hold power button, after 2 beeps, release this. Its reset video to default.
    Try and reply.
    Mar 2014
    Hi NickDiGi,
    Try it:
    Try and reply.
    I did all the steps, uninstalled old codec, installed new one, ran Ccleaner, reset PS3 stats and first I got this message again
    But after I shut down the program and opened it again, it appeared to fix that but now a new problem has come up. I assume it's reading my card now but at the bottom it says searching repeatedly and eventually it just times out.
  10. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Whats driver version used on C027??
    Mar 2014
    Um, I'm not sure, how do I check that?
  12. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Tap Key "Windows" + R to open RUN, type mmc devmgmt.msc, ENTER and check this about below:
    Mar 2014
    Mine apparently very old, where do I download yours?
  14. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Here: http://www.avermedia-usa.com/AVerTV/Upload/Download/C027_MCS1.7.9.12120509_Drv1.52.x.37_130124.exe
    Its contain software + drivers for Windows OS (XP, Vista, 7 , 8 and 8.1)
    Mar 2014
    Alright, everythings installed, and it finally reads it but now Amarec is displaying HDCP which makes no sense since it's going through my splitter. Any advice?
  16. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Open it in Avermedia Center. Close it and open in AmarecTV.
    Remember, you cannot record PS3 using any software. Only if u get "Special drivers + Softwares" here.
    Mar 2014
    It's working! Thank you so much for the constant help, I appreciate it.
  18. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    You are welcome.
