    Mar 2014
    Denmark
    Hi everybody.
    I'm almost at the point of ripping my hair out of my head, so i hope someone can help me.
    It can play this:
    General
    Unique ID : 203438903320308461048996425089411310624 (0x990CE856E308EDB38BCF2673A885E420)
    Complete name : F:\Film og Serier\Anime\Fullmetal ALchemist BrotherHood[Blu Ray] [Dual-Audio]\Fullmetal Alchemist BrotherHood 01.mkv
    Format : Matroska
    Format version : Version 2
    File size : 315 MiB
    Duration : 24mn 27s
    Overall bit rate : 1 803 Kbps
    Encoded date : UTC 2012-06-19 00:41:44
    Writing application : mkvmerge v5.6.0 ('Kenya Kane') built on May 27 2012 16:44:04
    Writing library : libebml v1.2.3 + libmatroska v1.3.0
    Attachment : Yes / Yes / Yes / Yes
    Video
    Format : AVC
    Format profile : High@L5.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 10 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 24mn 27s
    Nominal bit rate : 1 500 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.068
    Writing library : x264 core 104 r1683 62997d6
    Encoding settings : cabac=1 / ref=10 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:0.60
    Default : Yes
    Forced : No
    Audio #1
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 24mn 27s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : 9ms
    Default : Yes
    Forced : No
    Audio #2
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 24mn 27s
    Default : No
    Forced : No
    Text #1
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Compression mode : Lossless
    Title : [ASS]
    Default : Yes
    Forced : No
    Text #2
    Format : ASS
    Title : [ASS] [FOR DUB]
    Default : No
    Forced : No
    Menu #1
    00:00:00.000 : en:Prologue
    00:00:58.800 : en:Opening
    00:02:28.857 : en:Part A
    00:10:55.238 : :Part B
    00:22:27.555 : en:Ending
    00:23:57.353 : en:Preview
    Menu #2
    00:00:00.054 : en:00:00:00.054 / en:00:00:00.054
    But it can't play this:
    General
    Unique ID : 214419814124769709937354360232999062172 (0xA14FC10AAF41582286A51838E1930A9C)
    Complete name : F:\Film og Serier\Anime\Elfen Lied\[Daman] Elfen Lied 01 [1280x720_Blu_Ray_Dual_Audio_FLAC][71978425].mkv
    Format : Matroska
    File size : 861 MiB
    Duration : 25mn 12s
    Overall bit rate : 4 773 Kbps
    Encoded date : UTC 2012-12-31 05:43:42
    Video
    Format : AVC
    Format profile : High 10@L5.0
    Format settings, ReFrames : 16 frames
    Duration : 25mn 12s
    Height : 720 pixels
    Color space : YUV
    Bit depth : 10 bits
    Title : Elfen Lied Episode 01
    Writing library : x264 core 125 r2208 d9d2288
    Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 25mn 12s
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Bit depth : 16 bits
    Stream size : 80.8 MiB (9%)
    Title : English 5.1ch AC-3 448Kbps
    Language : English
    Default : Yes
    Forced : No
    Audio #2
    Format : FLAC
    Format/Info : Free Lossless Audio Codec
    Codec ID : A_FLAC
    Duration : 25mn 12s
    Bit rate mode : Variable
    Bit depth : 24 bits
    Title : Japanese 5.1ch FLAC
    Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
    Language : Japanese
    Default : No
    Forced : No
    Text #1
    Format : ASS
    Title : OP/ED/Signs
    Language : English
    Default : Yes
    Forced : No
    Text #2
    Format : ASS
    Title : English Subtitles
    Language : English
    Default : No
    Forced : No
    I don't have much knowledge of what all this means, but after some google'ing i found out it probably has something to do with it.
    So i hope it does, and i hope someone can help me figure it out, and maybe guide me through what to do.
    Thanks in advance.
  2. Perhaps because the second is "Format profile : High 10@L5.0" instead of "Format profile : High@L5.0". 10 refers to a 10 bit depth is used instead of 8. Perhaps your manual says something. You need to re-encode the second. You could try Xmedia Recode. It has preseet for Panasonic TV.
    Mar 2014
    Denmark
    Thanks for the answer. I will try this and see if it works.
  4. Banned
    Freedonia
    FLAC audio in the 2nd file is extremely unlikely to be an audio format that a TV media player will support, let alone the fact that this one is multichannel which is even less likely to be supported. It could also be that even if you fix the video issue (I too think that 10 bit is very likely a problem) that this FLAC audio either won't play at all or will cause the entire file to not play.
  5. jman is probably right about FLAC. However, if you re-encode with Xmedia Recode you should get an AC3 audio.
  6. Almost nothing outside a computer can play 10 bit h.264. Also settings like 16 reference frames and 16 bframes are problematic for most devices. Stick with High@L4.1 or lower for compatibility.
