  1. I bought an Amstron replacement battery for my HP Compaq 6510b and it takes three days to charge. Is this typical of new laptop batteries, such as http://www.akkus-laptop.com/hp-compaq-6510b-akku.html ? Do off-brand batteries not work well with Dells? What should I do?
  2. Member turk690's Avatar
    Jul 2003
    ON, Canada
    Charging Li-ion batteries is a critical operation; for safety, charging circuits inside a laughtop are designed optimally for the original battery that came with it. If it can't reliably detect what battery is attached and what charge condition it has, it will revert to trickle charge. If the off-brand battery has much higher capacity than the original, it may well also take much longer to fully charge.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  3. did the battery come with a disk to flash the bios so it would see the battery properly. i replaced a laptop battery on a sony vaio and had to that before it would even try to charge the battery.
    If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
    Want to extract audio from .vob files? Read my guide at http://www.dvdrhelp.com/forum/viewtopic.php?t=187078
