Results 1 to 10 of 10
  1. Tech_Girl DuBsTaR's Avatar
    May 2007
    I managed to capture a video stream, and have a bunch of F4F files. Can anyone advise on what I'll need to get this combined into one file format please. There is another topic on this but it's a mess and would like straight forward advice. Thanks in advance.
  2. Former Member
    Dec 2007
    The adobeHDS.php script is pretty much the way to join them, assuming the fragments don't have drm.
  3. Tech_Girl DuBsTaR's Avatar
    May 2007
    Hi
    No they don't. Could you link me to a tutorial on how to do this please ? I have taken the script, and put that to notepad, and saved 'all files' and have put the folder into my c: drive program files.
  4. Tech_Girl DuBsTaR's Avatar
    May 2007
    Nobody knows ??
  5. Never tried it, but how about:
    1. remux the files to mp4 using ffmpeg
    ffmpeg -i input_file.flv -acodec copy -vcodec copy output_file.mp4
    2. join and remux the files using MP4Box:
    MP4Box -cat input1.mp4 -cat input2.mp4 -new joined_output.mp4
    Cu Selur
  6. Tech_Girl DuBsTaR's Avatar
    May 2007
    They're f4f files.
  7. typo:
    ffmpeg -i input_file.f4f -acodec copy -vcodec copy output_file.mp4
  8. Can you post a few samples in the sequence ?
  9. Tech_Girl DuBsTaR's Avatar
    May 2007
    Thanks for this. I've uploaded a bunch around 20 MB inc txt file which shows the complete f4f files I have, not even sure if it's complete. Let me know what you can do. Thanks again.
    http://www53.zippyshare.com/v/74015181/file.html
  10. Former Member
    Dec 2007
    Do you have adobeHDS.php, and also have php installed (inlcuding php.ini) as per the adobeHDS.php wiki?
    Your files can be joined, I tested a few. But it seems you have some missing (gaps in the sequence # of the files), and also some different quality levels (1896/2596, etc). But definitely some blocks of them can be joined.
