I got a surveillance camera with motion sensors, the camera recored movement on a courtyard. So very movement is detected does the camera record a short video sequence. The problem is that the motion detector isn't that good so it might trigger from grass moving in a strong wind, which cause the camera to record quite a few unneeded clips. Therefor I would like someway to detect if there are any major changes in the video sequence, such as a human moving across the courtyard. Basically to filter out all the unneeded clips, the background is more or less static since the only difference is lightning condition.
There are avisynth scripts you can use . It's a scripting language that is very useful for manipulation for various audio/video tasks e.g.
http://forum.doom9.org/showthread.php?p=1628675#post1628675
If you have specific requirements (e.g. maybe there are unique conditions for your camera), the author is very good for feedback and will probably customize the script for you . There is stupid a 5-day wait to register at doom9 so I would register now if you haven't already -
Another possibility: in VirtualDub, goto the Options menu, choose Preferences, then adjust the scene change thresholds.
Subtitles in video : detect time position
By Urban20 in forum SubtitleReplies: 2Last Post: 15th Nov 2011, 03:24 -
how to detect a a keylogger for mac
By EmmaL in forum Off topicReplies: 3Last Post: 31st Aug 2010, 20:15 -
Using video presence detector to detect blank video signal from switcher.
By rabbi in forum Newbie / General discussionsReplies: 0Last Post: 6th Jul 2010, 01:30 -
PC can not detect Dv recorder
By dazedandamused in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Apr 2009, 18:45 -
Detect scenes in mpeg video
By cd090580 in forum Newbie / General discussionsReplies: 5Last Post: 6th Apr 2009, 10:37
