  1. I downloaded a VOB file and need to cut it a bit. I created IFO files from the video (with IfoEdit), fixed it with FixVTS and opened it in DVD Shrink to edit it. However, the video stream is shown as "Unreferenced Material". How can I fix that? What should I edit in the IFO file?
    You can cut vobs directly with for example mpg2cut2. It outputs a mpg.
    Or try reauthor the vob with something else than ifoedit like dvdstyler or muxman.
