Hello,
some months ago i got a samsung smart tv,
the problem its when you use default subtitle (movie file + sub file) the subtitles are so small and almoust impossible to read, so i had to find another alternative to fix my problem, and i did find.
i use "AVIAddXSubs" to create a idx/sub file with my type of font, and size, and after i use "mkvmerge GUI" to mix in one file,
everything gets fine, without a little problem... the outline its gets a light grey colour instead of black, and on light scenes its real hard to read sinze it kind mix with the image...
anyone have any solution to turn the outline in black?
Results 1 to 1 of 1
Subtitle outline render trouble with Avidemux
By Coco_coco in forum SubtitleReplies: 11Last Post: 8th Mar 2014, 10:04 -
VSDC Editor grey tab problem
By tai_97 in forum EditingReplies: 0Last Post: 25th Sep 2013, 09:49 -
Black outline with MaestroSBT and DVD-Lab Pro
By walruss in forum SubtitleReplies: 6Last Post: 29th Dec 2012, 10:52 -
MPC HC grey problem - how to fix (and clean video codecs in W7 x64)
By Mylo in forum Newbie / General discussionsReplies: 8Last Post: 16th Dec 2012, 05:53 -
I have rainbow colors on the outline of characters. Help me!
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2010, 17:20
