My computer has 2 monitors that are connected via DVI-D cable (fewer pins that DVI-I cable, a bit cheaper) and both has been working great however when I checked for Blu-ray restriction, everything passes except for the main monitor. The main monitor is SOYO Topaz-s 24" LCD is not HDCP compliant.
I've swapped the cable and switched the video port, the monitor won't be accepted by BD player.Is there anything I could do that isn't illegal (HDCO bypass or something) to get the monitor to work for full BD video benefit? Or did SOYO leave out something or what?
It's probably why SOYO brand monitors are so cheap (I mean that in both the good and bad sense of the word).
Encrypted (original Hollywood) Blu-rays will NOT work on that monitor, PERIOD, barring something drastic as you mentioned. Either decrypt them (while ripping) as mentioned by johns0, or use a valid monitor. Those are all your options.
If you go with ripping, you can decide whether it will be 1:1 to backup disc or ISO, or to different container, or to convert (re-encoding) to different format altogether.
Question monitor LCD durability
By gamemaniaco in forum ComputerReplies: 53Last Post: 20th Dec 2013, 01:23 -
Is monitor support only RGB content to display
By Aston in forum Newbie / General discussionsReplies: 7Last Post: 11th Mar 2013, 23:01 -
Multi-Monitor Setup Question
By VideoTechMan in forum ComputerReplies: 0Last Post: 11th Jun 2012, 02:26 -
Question on new monitor
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 22nd Nov 2010, 09:32 -
Dualboot and LCD monitor Question?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 02:53
