Results 1 to 30 of 32
  1. Hi to all,
    please I have 2 files from my gopro hero3+: one is 1080 (hd) and one is 720 (sd).
    Here I have upload hp.mp4 and sd.mp4
    please I would like transcode the hd.mp4 into .mxf in xdcamhd422 target.
    And I would like transcode sd.mp4 into .mxf in imx50 target.
    I use
    ffmpeg -i hd.mp4 -target xdcamhd422 -an test.mxf
    but result is:
    ffmpeg version N-61191-gea9399f Copyright (c) 2000-2014 the FFmpeg developers
    built on Mar 8 2014 22:01:33 with gcc 4.8.2 (GCC)
    configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
    isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
    le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
    e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
    ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
    ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
    eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa
    cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp
    ack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable
    -zlib
    libavutil 52. 66.101 / 52. 66.101
    libavcodec 55. 52.102 / 55. 52.102
    libavformat 55. 34.100 / 55. 34.100
    libavdevice 55. 11.100 / 55. 11.100
    libavfilter 4. 3.100 / 4. 3.100
    libswscale 2. 5.101 / 2. 5.101
    libswresample 0. 18.100 / 0. 18.100
    libpostproc 52. 3.100 / 52. 3.100
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'hd.mp4':
    Metadata:
    major_brand : avc1
    minor_version : 0
    compatible_brands: avc1isom
    creation_time : 2014-03-09 21:13:26
    Duration: 00:00:07.00, start: 0.000000, bitrate: 32078 kb/s
    Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709
    ), 1920x1080 [SAR 1:1 DAR 16:9], 30750 kb/s, 50 fps, 50 tbr, 180k tbn, 100 tbc (
    default)
    Metadata:
    handler_name : GoPro AVC
    timecode : 21:13:26:00
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 12
    7 kb/s (default)
    Metadata:
    handler_name : GoPro AAC
    Stream #0:2(eng): Data: none (tmcd / 0x64636D74), 0 kb/s (default)
    Metadata:
    Could not determine norm (PAL/NTSC/NTSC-Film) for target.
    Please prefix target with "pal-", "ntsc-" or "film-",
    or set a framerate with "-r xxx".
    The same problem I have in sd mode using:
    ffmpeg -i sd.mxf -target imx50 -an testsd.mxf
    My targets is xdcamhd422 when I use hd, and imx50 when I use sd.
    How can I resolve? thanks
    ps: I'm in italy so I use pal system
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I'm still waiting for the download to finnish............
    Do yourself a favor and use EyeFrame Converter. It will do all your transcoding using FFMBC with the propper commands. Give it a shot, I think it will help you greatly..........
    ***** Edit ****** I tried running it with FFMBC and it reported that XDCAM does not support 50 fps @ 1080 only @ 720. It looks like you'll either have to resize, change frame rate, or chose another output format like TS, mkv, or mp4
  3. Also me I have try with ffmbc but it have limitation of 1080x720... but I have to transcode it to reintroduce the output .mxf in my camcorder (pdw-f800) and it accept only xdcam hd 422.
    FFmpeg seem to using xdcamhd422 as target format but it don't wont transcode
  4. 1) 1080p50 isn't supported by xdcam - you would have to convert it to interlaced 1080i50 (also called 1080i25, same thing different naming conventions)
    2) Your "sd.mp4" file is 1280x720p50 , that's not SD imx specs - you would have to scale and interlace it as well
    3) Your gopro videos are flagged "full range" YUV (aka "yuvj420p", or 0-255). Different programs might handle it differently - be aware of potential levels issues
    I don't think ffmpeg has -target xdcamhd422 presets, only ffmbc. But ffmbc doesn't have -vf interlace filter (it hasn't been updated in long time). So maybe you can pipe ffmpeg (convert to interlace) to ffmbc
    ffmpeg -i hd.mp4 -vf interlace -an -f yuv4mpegpipe -pix_fmt yuv420p - | ffmbc -i - -r 25 -tff -target xdcamhd422 -an test.mxf
    yuv4mpegpipe doesn't support yuvj420p, so it will be "legalized" to 16-235 so point #3 is moot if you use this .
    If you want to keep it full range, you can use raw video pipe instead
    ffmpeg -i hd.mp4 -vf interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -f rawvideo -s 1920x1080 -r 25 -i - -pix_fmt yuvj420p -tff -target xdcamhd422 -an test2.mxf
    Or you can do these transformations through avisynth scripts , it will give you more control, probably faster (piping ffmpeg to
    Or use a different intermediate format that supports 1080p50 so you don't have to degrade the go pro videos by converting them to interlaced, and by re-encoding them
  5. Oh my cat, splendid examination.
    Only 1 answer: if I want encode using an "external" .wav file what I have to do? for example if I want encode with ffmpeg using a c:\song.wav how can I include it in the command line?
    thank you
  6. You use -i for multiple inputs, remove the -an (no audio), but -target xdcamhd422 has restrictions on the audio inputs I think, only mono tracks . You might have to use -map
  7. thanks poison, in fact my camcorder does not accept .mxf files without audio. Encoding video maybe it's ok: I have try also remove the "-an" option with no other but my camcorder does not accept the .mxf generated.
    I think that: it is necessary extract audio from the original .mp4, encode it PCM16bit and duplicate in the audio channel 1 and 2 of the .mxf
    is possible that? thank you
  8. You have to split the stereo to two mono audio tracks . You can use -map_audio_channel. This should work from a separate stereo source "audio.wav"
    ffmpeg -i hd.mp4 -vf interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -f rawvideo -s 1920x1080 -r 25 -i - -i audio.wav -pix_fmt yuvj420p -tff -target xdcamhd422 -an output.mxf -newaudio -map_audio_channel 1:0:0:0:1:0 -newaudio -map_audio_channel 1:0:1:0:2:0
  9. For the 720p to SD IMX50 case, using full range (if you want legal range, just use yuv4mpegpipe method above instead, or -pix_fmt yuv420p should scale it too)
    It's important the the order is done properly - progressive scaling from 1280x720p50 to 720x576p50, then re-interlacing it. That is piped to ffmbc for encoding. The imx50 preset will accept separate audio and mux into single 4channel track (final output is 608 height with the IMX spec), so no need to use -map_audio_channel
    ffmpeg -i sd.mp4 -vf scale=720:576,interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -f rawvideo -s 720x576 -r 25 -i - -i audio.wav -pix_fmt yuvj420p -vf colormatrix=bt709:bt601 -tff -target imx50 imx.mxf
    EDIT: you can add the -vf colormatrix to make it SD colors (Rec601)
    There should be a way in ffmbc to re-interlace, then you wouldn't have to pipe ffmpeg to ffmbc. Or if ffmpeg had -target xdcamhd422 or imx50 presets, then you wouldn't need ffmbc
  10. Why are you trying to put it onto your camera ?
    You probably need 24bit audio to make it compatible as well, so add -acodec pcm_s24le -ar 48000 before each -newaudio
    ffmpeg -i hd.mp4 -vf interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -f rawvideo -s 1920x1080 -r 25 -i - -i audio.wav -pix_fmt yuvj420p -tff -target xdcamhd422 -an output.mxf -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:1:0:2:0
  11. Originally Posted by poisondeathray View Post
    Dear poison,
    I have do a lot of proof:
    ffmpeg -i sd.mp4 -vf scale=720:576,interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -y -f rawvideo -s 720x576 -r 25 -i - -i spears.wav -pix_fmt yuvj420p -vf colormatrix=bt709:bt601 -tff -target imx50 -aspect 16:9 imx.mxf
    where spears.wav is the attached wav file
    tha camcoder (sony pdw-f800) accept the final output file IMX.MXF and can play as a normal file.
    If I exclude from the command line the "-i spears.wav", imx.mxf is unplayable by the camcorder maybe because there is no audio.
    To "extract" audio from original sd.mp4 file I have previuously to do:
    ffmpeg -i sd.mp4 -map_channel 0.1.0 -map_channel 0.1.1 -af "volume=volume=0dBrecision=fixed" sd.wav
    and using the sd.wav as audio file instead of spears.wav
    So this way I can reintroduce into the xdcam disc the gopro mp4 files: why? because my directors want it to avoiding transcode during editing in avid, to avoid wast hours for transcode .mp4 from the gopro.
    Poison, kindly, can I integrate the "ffmpeg -i sd.mp4 -map_channel 0.1.0 -map_channel 0.1.1 -af "volume=volume=0dBrecision=fixed" sd.wav" into the main string?
    thank you!
  12. Code:
    ffmpeg -i sd.mp4 -vf scale=720:576,interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -f rawvideo -s 720x576 -r 25 -i - -i sd.mp4 -map 0:0 -pix_fmt yuvj420p -vf colormatrix=bt709:bt601 -tff -map 1:1 -vol 256 -target imx50 imx50.mxf
    You might have to experiment with -vol for volume, because ffmbc is doing the volume manipulation, not ffmpeg (it doesn't use -af volume)
    -vol volume change audio volume (256=normal)
  13. Originally Posted by poisondeathray View Post
    Very thank you poison
    ffmpeg -i temp.mp4 -vf scale=720:576,interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -y -f rawvideo -s 720x576 -r 25 -i - -i temp.mp4 -map 0:0 -pix_fmt yuvj420p -vf colormatrix=bt709:bt601 -tff -map 1:1 -vol 256 -target imx50 -aspect 16:9 tempIMX.mxf
    with this, in SD, is possible encode from gopro .mp4 to .mxf and the camcorder accept the .mxf file: with SD or HD .mp4 file as source, and SD (IMX) target.
    Only now I try to encode from HD .mp4 gopro file to HD xdcamhd422 target, file .mxf is do but the camcorder does not accept as playable file
    I have try with:
    audio.wav = spears.wav
    is there a remedy?
    thank you
  14. Why doesn't the HD case play ? What is the reason ? For the SD case, it was lack of audio
    Do "normal" -target xdcamhd422 files generated from ffmbc play in the camera ?
  15. mm I don't know, seems when the .mxf file is not conform, the camera returns with a "Conncection closed; transfer aborted" without specify the reason.
    If I try to encode a .mxf file without audio or with the correct audio/video parameters, the camera returns alwais this "Connection closed; transfer aborted".
    Only for example, this is a HD .mxf file recorded by the camera (if I try to re-introduce it to the camera, it is playable):
    Generale
    Complete name : V:\uova\xdcam\C0020.MXF
    Format : MXF
    Commercial name : XDCAM HD422
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 23,4MiB
    Duration : 3s 240ms
    Overall bit rate : 60,6 Mbps
    Encoded date : 2014-03-09 18:36:09.000
    Writing application : SONY Opt 1.22
    Writing library : SONY Opt 1.22
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : 4:2:2@High
    Format settings, BVOP : Si
    Format settings, Matrix : Personalizzato
    Format settings, GOP : M=3, N=12
    Format_Settings_Wrapping : Frame
    Duration : 3s 240ms
    Bit rate : 50,0 Mbps
    Width : 1.920 pixel
    Height : 1.080 pixel
    Display aspect ratio : 16:9
    Frame rate : 25,000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bit
    Scan type : Interlacciato
    Scan order : Top field first
    Compression mode : Con perdita
    Bits/(Pixel*Frame) : 0.965
    Stream size : 19,3MiB (83%)
    Colori primari : BT.709
    Caratteristiche trasferimento : BT.709
    Coefficienti matrici : BT.709
    Audio #1
    Format : PCM
    Format settings, Endianness : Little
    Format_Settings_Wrapping : Frame (AES)
    Duration : 3s 240ms
    Bit rate mode : Costante
    Bit rate : 1.152 Kbps
    Channel(s) : 1 canale
    Sampling rate : 48,0 KHz
    Bit depth : 24 bit
    Stream size : 456 KiB (2%)
    Audio #2
    Format : PCM
    Duration : 3s 240ms
    Bit depth : 24 bit
    Audio #3
    Format : PCM
    Duration : 3s 240ms
    Bit depth : 24 bit
    Audio #4
    Format : PCM
    Duration : 3s 240ms
    Bit depth : 24 bit
    Audio #5
    Format : PCM
    Duration : 3s 240ms
    Bit depth : 24 bit
    Audio #6
    Format : PCM
    Duration : 3s 240ms
    Bit depth : 24 bit
    Audio #7
    Format : PCM
    Duration : 3s 240ms
    Bit depth : 24 bit
    Audio #8
    Format : PCM
    Duration : 3s 240ms
    Bit depth : 24 bit
    Altri #1
    Type : Time code
    Format : MXF TC
    Time code of first frame : 00:08:01:15
    Time code settings : Striped
    Altri #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    This is .mxf - IMX sd file recorded by the camera (if I try to re-introduce it to the camera, it is playable):
    General
    Complete name : V:\cesenaCalcio\C0052.MXF
    Format : MXF
    Commercial name : IMX 50
    File size : 992 MiB
    Duration : 2mn 13s
    Overall bit rate : 62.6 Mbps
    Encoded date : 2013-09-19 16:02:51.000
    Writing application : SONY Opt 1.41
    Writing library : SONY Opt 1.41
    Video
    Format : MPEG Video
    Format profile : 4:2:2@Main
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : N=1
    Format_Settings_Wrapping : Frame (D-10)
    Duration : 2mn 13s
    Bit rate : 50.0 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Original height : 608 pixels
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 4.823
    Stream size : 797 MiB (80%)
    Audio
    Format : PCM
    Duration : 2mn 13s
    Bit rate mode : Constant
    Bit rate : 12.3 Mbps
    Channel(s) : 8 channels
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Stream size : 195 MiB (20%)
    Other #1
    Type : Time code
    Format : MXF TC
    Time code of first frame : 00:36:39:15
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    This the file, SD playable by the camcorder, from the gopro and correctly transcoded with your string command:
    General
    Complete name : I:\GOPR0660.mxf
    Format : MXF
    File size : 440 MiB
    Duration : 58s 960ms
    Encoded date : 2014-03-16 18:14:41.000
    Writing application : FFmbc OP1a Muxer 53.6.0
    Writing library : FFmbc OP1a Muxer 53.6.0
    Video
    Format : MPEG Video
    Width : 720 pixels
    Height : 576 pixels
    Color space : YUV
    Bit depth : 8 bits
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    Stream size : 353 MiB (80%)
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Audio
    Format : PCM
    Channel(s) : 4 channels
    Bit depth : 16 bits
    Stream size : 86.4 MiB (20%)
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    But now I'm not able, only for my cat , to encode from gopro HD to .mxf xdcamhd422 target
  16. from http://code.google.com/p/ffmbc/wiki/XDCAMHD422Encoding:
    Introduction
    How to encode your content to XDCAMHD422 MXF or MOV
    Details
    Interlaced encoding: add: -tff or -bff before -target
    MXF
    ffmbc -i < file > -target xdcamhd422 < file.mxf >
    Note: XDCAM transfer supports no fewer than 2 mono tracks channels. Use -newaudio and -map_audio_channel.
    As an example, this command takes a stereo source file and makes an output file with two mono tracks.
    ffmbc -i < file > -target xdcamhd422 -an < file.mxf > -acodec pcm_s24le -ar 48000 -newaudio -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:1:0:0:1:0 -map_audio_channel 0:1:1:0:2:0
    This output file is compatible with Sony XDCAM Viewer.
    MOV
    ffmbc -i < file > -target xdcamhd422 -vtag < tag > < file.mov >
    Select tag from the following:
    "xd54" XDCAM HD422 720p24 CBR
    "xd59" XDCAM HD422 720p60 CBR
    "xd5a" XDCAM HD422 720p50 CBR
    "xd5b" XDCAM HD422 1080i60 CBR
    "xd5c" XDCAM HD422 1080i50 CBR
    "xd5d" XDCAM HD422 1080p24 CBR
    "xd5e" XDCAM HD422 1080p25 CBR
    "xd5f" XDCAM HD422 1080p30 CBR
  17. I don't know, maybe something is wrong with the preset in terms of compatibility ? It says it's compatible with xdcam viewer
    Or encode to DNxHD instead - that way it will be compatible in Avid. DNxHD is Avid's preferred format
  18. thanks poison, but we prefer encode in .mxf also to put the gopro in the camcorder to see directly on the broadcast monitor the gopro. We think is more easy also for editing.
    Considering my last post, is necessary the -vtag xd5c before the -target xdcamhd422 ?
    Or
    Can I encode from my hd.mp4 into .mxf (target xdcamhd422) with 2 (mono?) audio e.g. audio1.wav and audio2.wav? In this case what should be the command line?
    thank you
  19. The vtag isn't necessary, I think it's necessary only for MOV wrapped xdcamhdcam422, not MXF wrapped xdcamhd422. But you can try it if you want
    The last commandline for hd.mp4 split the stereo to 2 mono already
    View the export with mediainfo
  20. ffmpeg -i hd.mp4 -vf interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -f rawvideo -s 1920x1080 -r 25 -i - -i audio.wav -pix_fmt yuvj420p -tff -target xdcamhd422 -an output.mxf -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:1:0:2:0
    using audio.wav attached
    Resulting output.mxf does not work in the camcorder
    General
    Complete name : V:\uova\output.mxf
    Format : MXF
    File size : 45.1 MiB
    Duration : 7s 0ms
    Overall bit rate : 54.0 Mbps
    Encoded date : 2014-03-16 20:29:50.000
    Video
    Format : MPEG Video
    Format settings, BVOP : Yes
    Duration : 7s 0ms
    Width : 1 920 pixels
    Height : 1 080 pixels
    Color space : YUV
    Bit depth : 8 bits
    Stream size : 41.7 MiB (93%)
    Color primaries : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : PCM
    Duration : 7s 0ms
    Bit rate : 1 152 Kbps
    Channel(s) : 1 channel
    Bit depth : 24 bits
    Stream size : 984 KiB (2%)
    Audio #2
    Format : PCM
    Duration : 7s 0ms
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    Is possibly modify the string so audio used is directly internal audio of hd.mp4 instead of audio.wav?
  21. Originally Posted by marcorocchini View Post
    Unlikely to help, because it's essentially the same thing in 2 steps. Note the channel mapping syntax has changed, because 1st example was audio, this one has video & audio for hd.mp4
    ffmpeg -i hd.mp4 -vf interlace -an -pix_fmt yuvj420p -f rawvideo - | ffmbc -f rawvideo -s 1920x1080 -r 25 -i - -i hd.mp4 -map 0:0 -pix_fmt yuvj420p -tff -target xdcamhd422 -an output.mxf -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:1:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:1:1:0:2:0
  22. Originally Posted by poisondeathray View Post
    mm it's strange.
    However I have dowload 2 test file of example from here:
    http://hamburgpromedia.com/Testfiles/MXF_MPEG_Testfiles.php
    XDcam_HD4221080i50.mxf:
    MXF Testfile 1
    XDCAM HD422 1080i
    50Mbit, 8 Tracks Audio
    XDCAM_HD422_720p50.mxf:
    MXF Testfile 2
    XDCAM HD422 720p
    both files are playable by the camcorder.
    I have try:
    open XDCAM_HD422_720p50.mxf in virtualdub, and "AUDIO" --> Audio from other file --> spears.wav
    Save as avi in one file: gatto720.avi
    and then
    ffmbc -y -i gatto720.avi -target xdcamhd422 -an gatto720.mxf -acodec pcm_s24le -ar 48000 -newaudio -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:1:0:0:1:0 -map_audio_channel 0:1:1:0:2:0
    Result:
    gatto720.mxf unplayable by camcorder
    And then:
    ffmbc -y -i gatto720.avi -map 0:0 -tff -target xdcamhd422 -an output3.mxf -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:1:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:1:1:0:2:0
    Result: unplayable
    General
    Complete name : I:\XDcam_HD4221080i50.mxf
    Format : MXF
    File size : 73.0 MiB
    Duration : 10s 200ms
    Overall bit rate : 60.0 Mbps
    Encoded date : 2013-03-04 11:51:31.840
    Writing application : Hamburg Pro Media GmbH MXF4mac GC Export FCP 1.6
    Writing library : Hamburg Pro Media GmbH MXF4mac GC Export FCP 1.6
    Video
    Format : MPEG Video
    Format settings, Matrix : Custom
    Color space : YUV
    Bit depth : 8 bits
    Stream size : 60.8 MiB (83%)
    Audio #1
    Format : PCM
    Bit depth : 24 bits
    Stream size : 1.40 MiB (2%)
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Audio #3
    Format : PCM
    Bit depth : 24 bits
    Audio #4
    Format : PCM
    Bit depth : 24 bits
    Audio #5
    Format : PCM
    Bit depth : 24 bits
    Audio #6
    Format : PCM
    Bit depth : 24 bits
    Audio #7
    Format : PCM
    Bit depth : 24 bits
    Audio #8
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    General
    Complete name : I:\XDCAM_HD422_720p50.mxf
    Format : MXF
    File size : 73.5 MiB
    Duration : 10s 240ms
    Overall bit rate : 60.2 Mbps
    Encoded date : 2012-06-11 19:14:01.072
    Writing application : Hamburg Pro Media GmbH MXF4mac GC Export FCP 1.5.1
    Writing library : Hamburg Pro Media GmbH MXF4mac GC Export FCP 1.5.1
    Video
    Format : MPEG Video
    Width : 1 280 pixels
    Height : 720 pixels
    Frame rate : 50.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 1.085
    Stream size : 61.0 MiB (83%)
    Audio #1
    Format : PCM
    Bit depth : 24 bits
    Stream size : 1.41 MiB (2%)
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Audio #3
    Format : PCM
    Bit depth : 24 bits
    Audio #4
    Format : PCM
    Bit depth : 24 bits
    Audio #5
    Format : PCM
    Bit depth : 24 bits
    Audio #6
    Format : PCM
    Bit depth : 24 bits
    Audio #7
    Format : PCM
    Bit depth : 24 bits
    Audio #8
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    General
    Complete name : I:\gatto720.mxf
    Format : MXF
    File size : 65.1 MiB
    Overall bit rate : 53.3 Mbps
    Encoded date : 2014-03-16 21:36:31.000
    Video
    Format : MPEG Video
    Height : 720 pixels
    Color space : YUV
    Bit depth : 8 bits
    Stream size : 61.0 MiB (94%)
    Audio #1
    Format : PCM
    Bit depth : 24 bits
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    General
    Complete name : I:\output3.mxf
    Format : MXF
    Overall bit rate : 53.4 Mbps
    Encoded date : 2014-03-16 21:42:01.000
    Video
    Format : MPEG Video
    Height : 720 pixels
    Color space : YUV
    Bit depth : 8 bits
    Audio #1
    Format : PCM
    Bit depth : 24 bits
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
  23. Try it with 8 mono audio (ie. just re-encode it with -target xdcamhd422 setting)
    ffmbc -i XDcam_HD4221080i50.mxf -target xdcamhd422 TEST.mxf
    If that doesn't play , then there is an incompatibility between ffmbc's -target xdamhd422 preset, and in camera playback. You should file a report to baptiste
  24. ffmbc -y -i i:\XDcam_HD4221080i50.mxf -target xdcamhd422 TEST.mxf
    test.mxf unplayable by the camcorder
    General
    Complete name : I:\TEST.mxf
    Format : MXF
    File size : 62.2 MiB
    Overall bit rate : 51.2 Mbps
    Encoded date : 2014-03-16 21:56:46.000
    Video
    Format : MPEG Video
    Color space : YUV
    Bit depth : 8 bits
    Stream size : 60.8 MiB (98%)
    Audio
    Format : PCM
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Stream size : 956 KiB (2%)
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
  25. You can make "blank" or "silent" audio tracks, but try the 8mono re-encode test first. If that doesn't work, then there is no point going any farther, at least with ffmbc
    2 mono audio is the minimum requirement AFAIK
  26. can I modify the string so that the output .mxf file have 8 audio track (or channels?)?
    I don't know how... oh my cat
  27. You have to put -newaudio for each audio track, and -acodec pcm_s24le -ar 48000 if they are not already. Since the source audio is already 24bit 48000Khz, I ommitted them here for this test
    ffmbc -i input.mxf -tff -target xdcamhd422 output.mxf -newaudio -map_audio_channel 0:1:0:0:1:0 -newaudio -map_audio_channel 0:2:0:0:2:0 -newaudio -map_audio_channel 0:3:0:0:3:0 -newaudio -map_audio_channel 0:4:0:0:4:0 -newaudio -map_audio_channel 0:5:0:0:5:0 -newaudio -map_audio_channel 0:6:0:0:6:0 -newaudio -map_audio_channel 0:7:0:0:7:0 -newaudio -map_audio_channel 0:8:0:0:8:0
  28. Image Attached Thumbnails Click image for larger version
  29. What a sad cat!
    Hold on, there was a typo, I forgot to use -an for the first part, so there are 9! audio tracks
    This one should be correct
    ffmbc -i input.mxf -tff -target xdcamhd422 -an test2.mxf -newaudio -map_audio_channel 0:1:0:0:1:0 -newaudio -map_audio_channel 0:2:0:0:2:0 -newaudio -map_audio_channel 0:3:0:0:3:0 -newaudio -map_audio_channel 0:4:0:0:4:0 -newaudio -map_audio_channel 0:5:0:0:5:0 -newaudio -map_audio_channel 0:6:0:0:6:0 -newaudio -map_audio_channel 0:7:0:0:7:0 -newaudio -map_audio_channel 0:8:0:0:8:0
  30. nothing do to: my cat is too sad
    Unplayable.
    Also with:
    ffmbc -i input.mxf -tff -target xdcamhd422 -an test2.mxf -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:1:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:2:0:0:2:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:3:0:0:3:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:4:0:0:4:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:5:0:0:5:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:6:0:0:6:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:7:0:0:7:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:8:0:0:8:0
    Unplayable.
    General
    Complete name : V:\uova\test2.mxf
    Format : MXF
    File size : 73.1 MiB
    Overall bit rate : 60.1 Mbps
    Encoded date : 2014-03-16 22:52:56.000
    Video
    Format : MPEG Video
    Color space : YUV
    Bit depth : 8 bits
    Audio #1
    Format : PCM
    Bit depth : 24 bits
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Audio #3
    Format : PCM
    Bit depth : 24 bits
    Audio #4
    Format : PCM
    Bit depth : 24 bits
    Audio #5
    Format : PCM
    Bit depth : 24 bits
    Audio #6
    Format : PCM
    Bit depth : 24 bits
    Audio #7
    Format : PCM
    Bit depth : 24 bits
    Audio #8
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    This is the original input.mxf (XDcam_HD4221080i50.mxf) and is playable:
    General
    Complete name : V:\uova\input.mxf
    Format : MXF
    Video
    Format : MPEG Video
    Color space : YUV
    Bit depth : 8 bits
    Audio #1
    Format : PCM
    Bit depth : 24 bits
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Audio #3
    Format : PCM
    Bit depth : 24 bits
    Audio #4
    Format : PCM
    Bit depth : 24 bits
    Audio #5
    Format : PCM
    Bit depth : 24 bits
    Audio #6
    Format : PCM
    Bit depth : 24 bits
    Audio #7
    Format : PCM
    Bit depth : 24 bits
    Audio #8
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
