Results 1 to 9 of 9
    Mar 2014
    Hello, I am hoping someone can help me with an issue I am having. Seems my player in my car (Which is Window CE based) only likes certain MP4 movies. Looking at data for files in "MediaInfo", I think I narrowed down the issue. My player runs files like this...
    Video
    ID/String : 1
    Format : MPEG-4 Visual
    Format_Profile : Simple@L1
    Format_Settings_BVOP/String : No
    Format_Settings_QPel/String : No
    Format_Settings_GMC/String :warppoint0
    Format_Settings_Matrix/String : Default (H.263)
    CodecID : 20
    Duration/String : 1h 58mn
    BitRate_Mode/String : VBR
    BitRate/String : 2252 Kbps
    BitRate_Maximum/String : 16.8 Mbps
    Width/String : 852 pixel2
    Height/String : 480 pixel3
    DisplayAspectRatio/String : 16:9
    FrameRate_Mode/String : CFR
    FrameRate/String : 25.000 fps3
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bit3
    ScanType/String : Progressive
    But it does not run files like this...
    Video
    ID/String : 1
    Format : AVC
    Format_Profile : Main@L3.0
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 3
    frame2
    CodecID : avc1
    CodecID/Info : Advanced Video Coding
    Duration/String : 1h 48mn
    BitRate/String : 266 Kbps
    ColorSpace : YUV
    Bits-(Pixel*Frame) : 0.026
    StreamSize/String : 204 MiB (67%)
    Can someone please tell me what conversion in Audials 11 (or in any other converter) will output to the type my player will play. Seems it does not like AVC format but does like MPEG-4 Visual simple@L1.
    Assuming what I mentioned above is the reason some MP4 work and others do not, can someone help me? I have tried quite a few times to convert the bad files (AVC) to the MPEG-4 Visual Simple@L1, but have not been successful.
    Thank you in advance
  2. Looks like it wants your mp4 encoded with h263 codec. Just a guess on my part.
    I am not responsible, and it's been proven over and over again.
  3. I'm a Super Moderator johns0's Avatar
    canada
    The car player doesn't support MPEG-4 AVC which the second file is plus it resolution is too high(852x480),your will only play xvid at 720x480 with no special format settings.
    What type of device is your windows ce?
    Mar 2014
    Yes, I think that is the problem...the AVC format as the other works just fine. I am trying to find a way to convert the AVC to the other but not having any success.
    Also, I do have another movie that is the same as the one that works and it's resolution is 852x480 and it works fine. here is what that one reports...
    Video
    ID/String : 1
    Format_Settings_GMC/String : warppoint0
    CodecID : 20
    ColorSpace : YUV
    Compression_Mode/String : Lossy
    Bits-(Pixel*Frame) : 0.220
    StreamSize/String : 1.86 GiB (94%)
    Encoded_Library/String : Lavc52.76.0
    The unit I am using is the OttoNavi found here...
    http://www.ottonavi.com/Toyota-Tacoma-2005-2011-R2-Navigation-p/ty0511tc-rrtcnaxx.htm
    Thank you for the replies.
  5. There's lots of software which will convert h264 (AVC) video using a h263 encoder such as Xvid. If the converted video is only for playing in the car and you're not overly concerned about having lots of control over encoder settings etc, programs such as Video to Video Converter are pretty easy to use. It'll let you convert just the video while copying the audio, but you might also need to experiment with the type of audio your player supports.
    The player no doubt plays AVI files. You could open an MP4 with Video To Video Converter, select AVI from the conversion presets and you should be good to go. If you select MP4 you may need to change the default video and audio encoders. It's easy to do.
    By default, the AVI preset uses Xvid for the video encoding and converts the audio to MP3. The MP4 preset uses an "mpeg4" encoder for the video and AAC for the audio. You'll probably need to change the audio to something else such as MP3 or AC3. The mpeg4 and Xvid encoders should both give you video your player is happy with.
  6. Member Cornucopia's Avatar
    Xvid is mpeg4-asp (advanced simple). The one your player liked was mpeg4-sp (simple). Might be a passable difference, might not. You should check again with a valid SD rez xvid file and see if the player likes it.
    Btw, w/o a plug-in, QuickTime only creates sp, not asp mpeg4s.
  7. Video to Video Converter's "mpeg4" encoder results in Simple@L1. For Xvid it results in Simple@L3. That's what MediaInfo says anyway, for my 704x384 test encodes.
    Mar 2011
    Nova Scotia, Canada
    Here's the spec from the above link ... RYFM ...
    SCREEN SIZE: 7 INCH TOUCH SCREEN LCD
    DIN SIZE: DOUBLE DIN
    RESOLUTION: 800x480 PIXELS
    TOUCH SCREEN: RESISTIVE
    LANGUAGE: ENGLISH, SPANISH, GERMAN, ITALIAN & FRENCH
    BLUETOOTH: YES WITH A2DP SUPPORT
    MICROPHONE: EXTERNAL
    USB PORT: 1 IN THE REAR OF THE UNIT
    SD SLOT: 2 IN THE FRONT FACE OF THE UNIT
    RADIO: AM/FM DIGITAL TUNE
    RADIO SEARCH METHOD: LOCAL SEEK, RDS, TA PTY
    GPS: INTERNAL RECEIVER
    GPS SOFTWARE: FREE MAP ON SD CARD
    OPERATING SYSTEM: WINDOWS CE 6.0
    PROCESSOR: SAMSUNG high performance processor S3C2440A-40. Max. main frequency 400MHZ.
    MEMORY: 64MB SDRAM
    EXPANDABLE MEMORY: UP TO 64GB
    TV SYSTEM: NO
    VIDEO OPTIONS: BRIGHTNESS, CONTRAST, COLOR, SATURATION
    MEDIA FORMAT: MPEG-4(DIVX),DVD,DVD+R,DVDR,VCD,CD,CDR,CDRW,MP3,JPEG,WM A
    AUDIO OPTIONS: Built-in amplifier FR/FL/RR/RL 4-Channel audio output
    STEERING WHEEL FUNCTIONS: YES
    It says divx format. Clear as mud, as usual. Xvid would work fine, as you've found. They're both codecs that will implement the mpeg4 visual format..
    Nothing in the list about profiles or levels. There usually isn't. You could experiment by encoding to simple and advanced simple or just encode to simple. On a small screen it probably wouldn't matter.
    Mar 2014
    Thank you all. It appears that the Audials 11 I am using is just not providing the conversion I needed. The Video to Video seems to do what I need it to do. Now I just have to play with the setting to get it perfect for my player.
    Thank again!
