  1. Hello I'm new here but after searching the forums for
    help a few days to no avail I had to post this question.
    Video comes out black and white,
    distorted/scrambled after encoding in CCE SP 2.67.
    I'm using VirtualDub to frameserve to CCE SP 2.67 using .VDR extension.
    I can't get another working CCE version and can't find a download link to
    purchase their Basic software.
    The original AVI file is:
    Video
    Format : YUV
    Codec ID : YUY2
    Codec ID/Info : YUV 4:2:2 as for UYVY but with different component ordering within the u_int32 macropixel
    Duration : 44mn 43s
    Bit rate : 164 Mbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Compression mode : Lossless
    Bits/(Pixel*Frame) : 15.878
    Stream size : 51.4 GiB (99%)
    Thanks in advance.
  2. By the way, no matter what settings I use in CCE, video comes out distorted.
    For now I'm using the default settings.
  3. sorry folks, I got another version 2.70 and it works fine. ^^
  4. it seems like I'm having the same problems again with v2.70 after last night's encode.
    anyone have any ideas why this might be happening?
  5. here's a screenshot of what I'm talking about:
  6. any help, would help.
