    Jan 2003
    Away from the Equator
    Hi
    I had two OS folders in my C: drive: WINDOWS and WINDOWS.0 (both WinXP), and booting was possible from either by choosing from booting preference menu. Since the second folder was more recent, that is the first boot choice.
    Now the WINDOWS.0 folder has been deleted manually, so now the first boot choice is invalid and the machine stalls if the second one is not selected before the timeout. This is a nuisance.
    How can I remove this first boot choice from the booting screen in simple uncomplicated steps ?
    Thanks.
  2. Edit the BOOT.INI file in the root of drive C: and change the default.
  3. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Control Panel - System & Security - Admin Tools - System Config - Boot Tab
    You should be able to delete the second entry here.
    Rog
    There are many ways to measure success. You just have to find your own yardstick.
    Jan 2003
    Fine, fine.
    You guys are great.
    Thanks, jagabo and burnman99.
