  1. Hi to all!
    I have a film (Titanic) splitted in two DVDs: I converted them in mkv using Handbrake, then, I merged the two parts with MKVToolNix, but MKVToolNix inexplicably changes the colour of the subtitles of the second part, from white to orange.
    I really don't know why this odd behaviour, and I tend to think it's just a bug.
    Or anybody could suggest something I can try?
    Many thanks in advance!
    I'm Winston Wolf. I solve problems.
  2. The color of DVD subs is determined in the IFOs and not the BMPs. The subs are in what format? VobSubs (IDX/SUB)? If so, you can fix them before importing them into MKVMergeGUI using VobSub Configure as I don't see any way to also import the IFOs into MKVMergeGUI to get the correct colors. Maybe someone knows more about how to 'fix' the colors.
  3. I'm a Super Moderator johns0's Avatar
    canada
    You can fix the colors with BDSup2Sub as long as they are in IDX/SUB,then you save them to sup(blu-ray) or IDX/SUB.
