    Jan 2010
    Wow, it has been a very long time since I've been here. I recently got the urge to look at my vhs tapes again and I pulled out my old ADVC devices.
    The ADVC 55 works fine, however I am having issues with my ADVC 300. Unfortunately the software no longer works with modern operating systems on a mac, and while I can hook it all up and read the unit in imovie, I cannot switch the incoming source from digital to analog.
    In the past I was able to correct the problem by running the picture controller software, but since that won't work with snow leopard, I'm at a loss as to what to do.
    Is there any hope to get this to work properly, or is my best bet in sticking with my ADVC-55?
  2. Member DB83's Avatar
    Jul 2007
    Set Switch 8 to 'OFF'. Unit then no longer controlled by a PC
    Jan 2010
    Oh thank you thank you thank you!!! It's working! I was tearing my hair out over this $300 purchase turning into a doorstop. Can't wait to play again
