  1. Problem i'm having is that MadVR is rendering to a rectangle of 1280x720 when I go to fullscreen. I need it to go to 1920x1080. I don't have this issue in MPC-HC... anyone know how to fix this? Thanks in advance.
  2. I'm not sure what you're exactly talking about but I have no such an issue.
    Backup your potplayer settings and try to reset the player in preferences. That's the first thing you should try.
  3. The issue is that the max resolution of Potplayer with MadVR seems to be 720p and not 1080p. I've tried it with default settings and also adjusting all the screen setting to 1080p. But every time I play a moving and hit Control-J on MadVR to see what it's doing... it's only rendering up to 720p for whatever reason. In MPC_HC, it shows that it's rendering up to 1080p.
  4. You can check the video output resolution of potplayer in playback info screen.
    If the output shows 1080p correctly, it may be madvr issue for some reason.
